Question about Saniflo 030 Extension Pipe for Installing Sanibest & Saniplus Behind Wall
Discharge elbow leaking macerator
Hi, I have a Sanitop Broy Pro. The macerator appears to be pumping correctly, however there is a leak from the side of the discharge elbow. I have tightened the jubilee clip but water keeps leaking from the side where the rubber seal meets the top of the lid. Does anyone have any idea what could be causing this? Regards, S
  • 145 Answers
SOURCE: Saniflo Sanitop pump keeps running
CHECK YOUR OWNER BOOK
Posted on Dec 12, 2008
  • 44 Answers
SOURCE: macerator leaks badly
Hi ya,
the macerator will dispose of most stuff, providing its within the manufacturers requirements.
The unit is made of stainless steel so it should be ok, however the seals are made of neoprene & according to the amount of perm solution put down the unit, especially as its quite acidic, so it could be leaking due to the seals being eaten away by the perm solution etc.
My advice would be to dilute the solutions as soon as you put them in the unit & run water so as to make sure it doesnt sit in the unit.
But however my professional advise would be to dispose of it down a suitable drain point.
If you look on the saniflo website they will direct you to a service engineer in your area
Kindly
Richie
Posted on Dec 16, 2008
  • 659 Answers
SOURCE: Very Noisy Sanitop Macerator
http://owneriq.net/
You will probably be able to find a user manual on the above link. It will tell you whether or not there has to be maintenance on this toilet. I doubt it but it is possible. There should also be trouble shooting advice as well. When all else fails, contact the manufacturer. They will be able to tell you what the problem is and guide you in the right direction.
Posted on Mar 21, 2009
  • 2463 Answers
SOURCE: Replacing the seal.
Hi you could try soaking it in warm water to make it soft then it might stay on
Posted on Jan 25, 2010
  • 33 Answers
SOURCE: Our macerator allows water to go to top of toilet
blocked or VERY dirty saniflo. This unit will have to be removed for complete cleaning and descaling. check the 22mm outlet pipework for blockages. Once spotless, check the unit for operation and then reinstall. Se my other posts for how to.
Posted on May 10, 2010
My saniplus leaks/sprays watse from the discharge elbow at the base of the unit, it is popping up and leaking during discharge
no,you need to take it apart and replace the gaskets,they are under pressure and glue will never hold,read about it here, Saniflo Extension Pipe
Sep 16, 2014 | Saniflo SaniPack SaniPack Concealed...
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo keeps going off when not flushed
Water pressure makes the unit turn on and off. If it turning on by itself then could be water draining back into the pump. Water could be leaking from the check valve on the discharge elbow into the pump or from the toilet tank into the bowl. Inspect the flapper on the check valve and the flapper on the flush valve.
Aug 09, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
How do I know if the macerator is working if I flush the toilet I acn hear the pump start and see the 22mm outlet pipe vibrating as water is pumped thru it. But I'm not sure if macerator is working. Does...
If you flush the toilet at least 3 times and water does not back up on the toilet then is working. In case the pump fails the pump will fill up about 3 to 4 gallons of water before it overflows or backs up. You can also try disconnecting the discharge pipe off the discharge elbow and place a bucket at the end of the discharge elbow and flush the toilet into the bucket, if water is discharged into the bucket then is working properly.
Jul 20, 2010 | Saniflo & Saniplus& Macerator Pump
The outlet spout keeps popping out after a few days of working the outlet pushes the rubber bush out ejecting the waste water onto the toilet floor
I believe you are talking about the 90 degree rubber elbow on top of the pump where the waste discharges. There is a rubber hose sticking out the top of the pump casing about 1/4" you need to inset the check valve and press down as far as it goes, next step you have to push the rubber elbow on top and also press as far as it goes, then the last thing you put on is the clamp which will tighten the rubber elbow against the check valve and the rubber hose sticking out the top of the pump. This will stop the leak and will prevent the elbow from blowing out of the unit. But it must be done in the same sequence as i explained.
Mar 08, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo 030 Extension Pipe for Installing Sanibest & Saniplus Behind Wall Logo
47 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
