HP DESKTOP desktop media provilion m8200 installed window 8 it worked for a few days. i disconnected internet and screen went blank, and never recovered, fan works, and on light flashes, monitor says computer is in save mode, press many buttons but no response
Hi had this same problem. unplug computer tower an use another screen, i used my tv. plug vga into tv an turn on computer. go to Control panel and then Devices. look for your monitor an uninstall it from computer. then shut down the compter unplug an replug back into your lcd monitor it will automatically reinstall it for you. hope that works. just a pain havin to move it!
Posted on May 08, 2013
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
informatica
  • 1114 Answers
SOURCE: Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: http://us.lge.com/filedown.do?filepath=1000000757&fileName=L1750B-BF.pdf Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Posted on Jul 30, 2007
tantong
  • 138 Answers
SOURCE: Blank ACer X221W Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went dim and blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 06, 2008
SOURCE: My MAG Innovision Monitor went blank, only works if I stay connected to internet
I had the same problem. Luckily I was still in warrenty and I sent it back to mag and they fixed it.
Posted on Oct 17, 2008
  • 24 Answers
SOURCE: W1941S monitor flashing OSD Locked/ OSD unlocked alternatively
Sounds like virus.Tryto start in safemode then run virus protection and afterward install a firewall.
Posted on Jan 06, 2010
Testimonial: "Thanks wce3. I guess it was a virus. i followed the steps and then tightened the noose for the existing firewall i had and the prob is not happening. "
Time day clock stopped
run an anti virus and if that does not work go to the right of your screen and put in the search box your question, a solution should pop up .if not call the maker of your computer to see if they can help and since its under warranty they should help you for free. I called mine and since it was still under warranty they helped me!
Jan 29, 2014 | Acer Aspire Computers & Internet
I cannot open links. When I click on them I get a blank dark screen
That is because somehow the internet explorer 10 is not working.
Just open the desktop version of internet Explorer. It will work.
May 02, 2013 | Computers & Internet
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
Mar 16, 2013 | HP Pavilion a705w PC Desktop
Ipconfig media disconnected
You may need to go to the linksys website and download a patch.
Sep 16, 2012 | HP Pavilion a1419h PC Desktop
Can't connect to the internet. It says media disconnected on windows 7
Sounds like your internet connection is down. Check your modem and router (if you have one). Check the actual connection to see if wires are loose. It's telling you that there is no connection between your computer and any other device.
Feb 27, 2012 | HP Pavillion s7420n PC Desktop
Blue screen error
Check your bios and see if you have the anti virus turned on. If you do then turn it off. Anti virus prevents windows and other operating systems from accessing the bios portion of the computer. If this works then don't forget to turn ON the anti-virus when you are done installing the new OS
Jun 04, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
Dell Desktop, wont power up..monitor goes blank
Remove the cable. Keep pressing F8 while you power on the system and choose safe mode, press enter. Screen will roll up a few pages and stops for a while. wait a few minutes. windows will start in safe mode Scan for viruses. Restart. It is a virus problem
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Computer boots up but goes blank after a few seconds!
Can you enter BIOS Setup menu by pressing F2 or DEL before it boots - does same thing happen?
If so then monitor is the problem - check cable connections - try a different monitor...
Aug 13, 2008 | HP Pavilion dv6000z Notebook
Cant see desktop screen
Try this if your problem sounds the same or similar:
I purchased the HP-Compaq C765TU Presario, serial # CND81233B5, from Octagon Computers. My notebook came with only "Freedos" because I was going to Dual-boot Windows XP Professional & Linux, but I found out that my notebook is only “Vista Compatible,” because I could not find the drivers for the sound card & Atheros wireless adapter & the Linux I used, Ubuntu does not have all the drivers needed, so I uninstalled, & I added the only Windows Vista OS that I could get here at Octagon Computers in Tacloban City, Leyte, Philippines, “Windows Vista Starter!” (I’m an American married to a beautiful Filipino woman 1 year younger than me, & we are living in the Philippines. I’m, also, Retired USAF.) I went to the HP-Compaq site & downloaded all the new drivers and essential update for my notebook to make sure my notebook was as it should be by HP-Compaq standards. All is well, but only for a little while!
The first problem that I encountered was that after I would Logon, the Welcome screen would do its processing then go to a blank desktop with the cursor - no icons, no taskbar, nothing, so I used “control, alt, delete” to bring up the tasks page & started Task Manager. I found that the “Explorer.exe” was not listed, so I ran a “New Task” from the file menu, & my whole desktop came up. The notebook runs fine after this is done, but I had to do it all the time.
So, I found & bought a copy of Windows Vista Ultimate on the Internet & was forced to do a clean install because it was a full version (not an upgrade), which formatted my Hard-drive, but I had backed up all my files ahead of time, so as to not lose all my important data. I went back to HP-Compaq site & downloaded all the new drivers and essential update to make sure my notebook was as it should be by HP-Compaq standards. After doing this New Install, my notebook worked perfectly! However, the same problem has come back as I had with Windows Vista starter.
I have always used Anti-virus, and I run “System Mechanic Professional 8” because it has all the tools needed to seek & destroy viruses, spybots, etc…, & recover/repair data.
I have never had this problem with Windows XP Professional, but this laptop is designed for Vista, and I didn't know that before I bought it. I'm still looking for a permanent FIX. There must be a way to fix this problem permanently!
Sep 18, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
