Dht 222 CODE REMTE CONTROL???
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
0381,0374,0628,0917 are the codes to check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box, can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on May 08, 2013
I need help setting up a 5 way remte control to a Magnavox sdtv converter box
If the remote is universal, you can do a code search to find something that works. If searching doesn't work you may have to try a different remote. Some of the newer remotes such as Philips, RCA, and GE have specific SDTV codes.
Sep 11, 2016 | Magnavox Televison & Video
How do you reprogram a ge universal remte for my philips
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://remotesearch.blogspot.com/
Aug 20, 2014 | GE RM24912 Universal Remote Control
Code 4605b01
The GameChanger ESPN Remote Control codes for an Emerson TV (only tv, now combo) are Emerson 007, 008, 011, 013, 014, 022, 037, 161, 218, 219, 222
Jun 04, 2013 | One For All URC-4605 Remote Control
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit
if this is a bizhub 222 the toner density error code would be c2557
May 10, 2012 | Konica Minolta Bizhub 222 Black and White...
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Aug 28, 2009 | Minolta Office Equipment & Supplies
Need remte control f grave digger rc
NICE! got one too! did it come with a receiver in it or were the guts pulled out? most likely going to be easier to hit a hobby shop or ebay and pick a new system out for it because if it did come with a receiver to be reliable you should match brands after that you will need to make sure the crystals are matched for frequency good luck have fun I think some parts for it may be getting hard to find.
Aug 07, 2009 | Tyco Toys
Change area code of device please
1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
2. Enter RC6 command via Pronto
[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
2.1. The remote should be set up to control the DVD (setup code 0539).
2.2. Press the DVD button.
2.3. Press the Magic button.
2.4. Press 085.]
2.5. The display should read '----'.
2.6. Enter the following with the normal Philips remote:
[On newer models, there appears to be 11 spaces in which to enter a code].
222 222 005 255
The player should now be able to output pal progressive scan + be region-free.
May 23, 2009 | Philips DVD963SA DVD Player
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
