Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
183760 000 heater won't kick on
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
72cc pitbike kick start won't come back up after you kick it down ...?
mate whats happening is there is no recompression inside the engine pushing the gear to return id say you have done the gears in it and it would cost more to replace them than to replace the engine
Jan 28, 2013 | Pit Cycling
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
My car won't start it kicks over but won't start
It has to be one of only 2 problems. No spark or no gas. Check both to make sure they are being supplied.
Jun 03, 2012 | 1996 Ford Contour
No heat till you start driving and then fan will kick on and not shut off but it doesnt overheat
You won't get heat right away. The heat has to have time to reach the heater core. That's where you get the heat for the passenger compartment. But if the fan isn't turning off, then I would have it checked for an electrical problem.
May 05, 2012 | 1999 Dodge Caravan
When I push the arrow up to make my heater kick on a 1+2 pops up above the temperature number and it won't kick on.
sounds like your touchscreen is messing up and your adjusting the T-factor.. try pushing the reset button on your thurmastat.
Feb 26, 2012 | Heating & Cooling
My AC/heater won't blow and the rear defrost won't work. For a while if I smacked the dash or kicked the transmission housing it would kick on. It won't work at all now except for a random...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:6
Aug 12, 2011 | 1996 Oldsmobile 88
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
79 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
