Question about Taylor New 7544bl Biggest Loser Cal-max Glass Scale 2.3 Inch Lcd Display
How do you replace the battery on the 7544BL Cal-Max Scale
We can't see how you get the battery out to replace it and have lost our instruction booklet. HELP!
    New Friend:
    Problem Solver:
How do I replace the battery in my Taylor 7544BL Cal-max scale.
We removed the back and the lithium battery is positioned oppisite the opening?
Posted on Dec 18, 2014
How come my scale will shut off on it own and not display my weight
depends it may have a power save feature, this will shut of the scale after a set amount of seconds. or it may be faulty. check the user guide to see if it is power save.
Aug 29, 2014 | Taylor Biggest Loser 7206 Electronic Cal...
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
Aug 20, 2014 | Office Equipment & Supplies
Shows 0.0lb no weight
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
I replaced the battery and now the scales read "Err" what do I do now?
I own a cal-max digital scale and i replace batteries and still not working it is showinn err
Feb 27, 2011 | Taylor & Digital Scale Lithium Scale
When you step on it and get the err1 message step off wait a few seconds and step back on, remember that while the scale is processing your weight you MUST remain STILL.
good luck
Aug 12, 2010 | Taylor Biggest Loser 7206 Electronic Cal...
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Taylor New 7544bl Biggest Loser Cal-max Glass Scale 2.3 Inch Lcd Display Logo
790 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
