Konicaminolta magicolor4690mf code on display 0f50
How do i reset 0f50
Over head transparencies sensor is bad.
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
ERROR CODE CALIBRATING
Might require having the firmware up graded get a konicaminolta tech out to up grade the firm ware from a secure konicaminolta web site.
Jun 06, 2014 | Konica Minolta bizhub C351 All-In-One...
I have a KonicaMinolta Magicolor 3730DN. It fails with Fatal error code 0F55H.
Toner level sensor for the black toner is bad or the black toner is not getting into section where that sensor is. ensure your black toner cartridge is OK
Oct 05, 2012 | Minolta magicolor 2200 DeskLaser Printer
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Code 0f50 on konica
Code 0f50 error on konica minolta bizgub c20 how to slove this error?
May 10, 2011 | Office Equipment & Supplies
Display C 4551 open and close front door to reset. Minolta magicolor 8650
Cyan print has failed get it replaced, If you get a KonicaMinolta tech he can try a firmware fix you must have access to KonicaMinolta secure web site for the firm ware.. Normally what is done are all four print heads are changed in one setting
Jan 27, 2011 | Minolta Office Equipment & Supplies
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
When using flash it flashes multiple times when taking picture..strobe flash
Hello
You will find that if the flash pulses slowly several times before taking the main picture you have got the camera set to red eye reduction flash, you will see an eye symbol on the display.
Check the owners manual for the method of changing this to the setting you need.
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_400si/Maxxum400siManual-Part1.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part2.pdf
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_maxxum_500si/Maxxum500siManual-Part3.pdf
Above are the links to download the owners manual for this camera.
Hope this helps
Sep 25, 2008 | Minolta Maxxum 400si 35mm SLR Camera
70 people viewed this question
jasbo
jasbo
