Question about Lexmark P6250 All-In-One InkJet Photo Printer
Lst ints disk can't get print to reinst
My printer want recon. with comp. how do i get a new disk
    Sergeant:
  • 390 Answers
You need to get your local brand printer suppliers contact and physically apply for a new disc or a copy of one. Sometimes you can download it over the internet, but this is risky as it can download incorrectly or have read errors. Getting a new disk is the better way to go. I assume it is a new lexmark, not rebuilt etc. As you do not specify your location, i cannot direct you to your nearest lexmark centre, so type lexmark (your country/area) in ggogle searchbar, and follow best link. Search their database for your brand, contact them to get new disc.
Posted on Aug 11, 2007
Write a program that creates a linked list of characters from a string entered by the user. (The string can be initially entered into an array if you wish.) Your program is then to move the second part...
Here's a brute-force C++ program to do it, assuming FixYa doesn't mangle the formatting. The last loop merely outputs the resulting list, since it makes no sense to just do all the work without showing the result.
#include <iomanip>
#include <iostream>
#include <list>
#include <string>
using namespace std;
int main()
int brk, j;
list<char> lst;
string str;
cin >> str;
for (string::const_iterator i(str.begin()); i != str.end(); ++i)
lst.push_back(*i);
cin >> brk;
j = 0;
for (list<char>::iterator i(lst.begin()); j < brk; ++j) {
lst.push_back(*i);
lst.erase(lst.begin(), ++i);
for (list<char>::const_iterator i(lst.begin()); i != lst.end(); ++i)
cout << *i;
cout << endl;
return 0;
Nov 01, 2013 | Televison & Video
I tried to use my printer (hp 2115) after installing many other programmes and not using the printer for a while. It prints from excel not word, when it does print from word it only prints one line of the...
► do a L4 uninstallation i.e. by putting the disk for printer.... explore and go to Util and then CCC ... then select uninstallL4
► restart the comp
► download the driivers from Hp.com and then install it
► restart the comp
BEST OF LUCK
Feb 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
Need to print a report of past print jobs
If you have CentreWare IS you can do the following (taken from the manual):
You can find the manual link here: http://www.office.xerox.com/userdoc/P6250/6250_Web/pdfs/reference_guide.pdf
On page 97 of the manual it states:
Using Printer Management Features
Job Accounting
The printer stores information about print jobs in a log file. The log file is stored either in the
printer’s memory or on an optional hard disk if one is installed in the printer. If the log file is
stored in the printer’s memory, it is lost when the printer is reset. It is recommended that a hard
disk be used for job accounting.
The log file lists job records. Each record contains fields such as user name, job name, pages
printed, job times, and toner and ink used. Not all fields are supported by all printers. For
information go to CentreWare IS online help or CentreWare Web online help.
The job accounting values reported vary depending on the protocol and print command used
when each job was printed. For example, using NPRINT over NetWare provides the printer
with the most information about the job being printed. When using Windows and NetWare, the
job name is often LST: or LST:BANNER. Other jobs from other ports may provide less
information about the job.
Job accounting is available through CentreWare IS and CentreWare Web.
Using CentreWare IS
1. Launch your web browser.
2. Enter your printer's IP address in the browser’s Address field (http://xxx.xxx.xxx.xxx).
3. On the right side of the main CentreWare IS page, click Jobs.
The “Job Accounting Links” page provides links that enable you to browse, download, and
clear job accounting records.
For complete information on CentreWare IS job accounting, including clearing job
information, downloading job information to a file, and job accounting file formats, go to
CentreWare IS Online Help.
Hope this helps!
WizardRepair
Jul 17, 2009 | Xerox Phaser 6250DP Laser Printer
Lexmark X1150 printer copier scanner stop working with new comp.
that a usual problem among printer that cannot print of a vista OS..I suggest that you will use a windows XP .
May 14, 2009 | Lexmark X1150 All-In-One InkJet Printer
HP 5510 Just stopped working properly in the middle of a doc.
Well, thet just proves that the problem is with the printer itself. I would guess that it is an issue with either the memory or the print engine itself in which case it would most likely require a trip in to a qualified HP service center to resolve the issue.
Sorry I don't have better news for you.
Mar 10, 2009 | HP Officejet 5510 All-In-One Thermal...
PQI 1GB Intelligent Stick USB 2.0 Flash Drive
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Dec 03, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Hp psc 1210v all in one
hi,
delete the printer icon from the control panel.
unplug the usb cable from the printer
re insert it after few seconds and then wait for another minute
now try
thanks
agnel
Oct 06, 2008 | HP PSC 1210v All-In-One InkJet Printer
Not printing
is there any flashing lights, try to check the printer cable or reinstall the driver..
Jun 22, 2008 | HP DeskJet 880c InkJet Printer
Printing on disk
sounds like a bad format on the cd that the printer does not like try a different old bundle of cd's from a fresh pack
most older cd's these days are not excepting new format cd's for some odd reason its not the cd but the player
the cd's using a new polymer coating that old decks cant reconize
theres also the posiblity the cd r is worn and just need a replacement
May 21, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
