This is a problem with flash on your computer which is what is crashing when the CD is auto ran. To work around this you need to leave the CD in the tray after you get this error and go to My Computer and look for the CDrom there and right click on it and select explore. While exploring the CD you will want to look for the folder that is the name of the version of Panda you have. Inside this folder there will be a SETUP file which you could run from.
If the above is unable to be done, you may download your version of the software from the below link
Panda Internet Security 2009
http://support.us.pandasecurity.com/retail/Products/PIS09.exe
Hope this helps
Ernie
Panda Support
Try this, rename the professional folder in C:program files\common files\InstallShield.
There should be a folder called Professional and reneame it to something like Profess. You should be able to install the program with the CD.
I HAVE PANDA ANTIVIRUS PRO 2009 AND IT WONT LET ME DOWN LOAD AND I ALSO GET LANZADOR INSTALADORES STOPPED WORKING.
I have the same problem when I try to install Panda Antivirus Pro 2009....I get the message,,,,Lanzador Instaladores has stopped working...I tried renaming the file from professional to profess and I still get the same message
I have the same problem and I have e-mailed Panda and have not heard from them. I have Vista and I am not sure if this is the problem or not.
