Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Washer won't drain or enter spin cycle
I'm pretty sure it's not the lid switch, because the washer shuts off when I lift the lid during agitation cycle. I've also replaced the pump, but to no avail. I checked the drain lines and nothing was clogged or kinked. I'm at a loss as to what to try next. Any ideas? Thanks in advance.
  • Michael Ryan Jones Jun 04, 2013
    I was unaware that the switch is a two part device. All of the other people seemed to have left out that nuance on other sites. Thank you for the assistance. No more laundromat for me.
    New Friend:
SHOULD BE THE LID SWITCH... THERE IS TWO SWITCHS INSIDE, ONE THAT STOP THE MACHINE, AND ONE TO LOCK THE DOOR. YOU SHOULD SEE THERE IS TWO PAIRS OF WIRES THAT CONECT WITH THE LID SWITCH, ONE PAIR IN THE FRONT, AND ANOTHER PAIR IN THE RIGHT SIDE, THAT RIGHT SIDE IS THE PROBLEM, INSIDE THE LID SWITCH MUST BE BROKEN. TRY TO MOVE THE PLATED LOCKING PIN IN THE DIRECTION THAT LOCKS THE DOOR, AND IT MIGHT DRAIN AND SPIN. IF THAT THE PROBLEM, YOU SHOULD GET A NEW SWITCH (MODEL 134101800), AND YOURE DONE.
GOOD LUCK
MARIO
Posted on May 29, 2013
watugot
  • 290 Answers
SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
jumptrout51
  • 3361 Answers
SOURCE: will fill and drain wont agitate or spin
Replace the lid switch.
Posted on Mar 11, 2009
SOURCE: Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Posted on Mar 25, 2009
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
SOURCE: ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Posted on Apr 12, 2010
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSQ8543JQ1, washer stopped full of water, will not start back up, seems like no power to it, check fuse box and everything else that is running of same.
Pretty much exactly what guest above me said. I have a lsq8543jq1 also, was stopping after agitation.
At first thought it was something more serious, since the dial seemed to make a humming/grinding/buzzing noise when it was switching to agitation cycle, but that seems to just be a timer before the drain/spin cycle kicks in.
I had a washer full of water, so rather than wait till I could get a part (or hand drain -what a pain), I just grabbed a paper clip and rigged the switch so it thinks the door is shut and voila, drains and finishing cycle as I type.
The switch is a safety device to prevent accidents; bad injuries could result if the door is opened while the washer is in spin cycle. I don't recommend this as a long term solution - especially if you have kids. I have 2 and will be ordering the new part asap.
Apr 06, 2008 | Washing Machines
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
438 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
