Question about Vizio XVT3D474SV 47 in. 3D LCD TV
Picture is mirrored horizontally
I recently moved and when I plugged my TV back in, the display is mirrored horizontally. The bottom is upside down (Profile: Guest menu is in the bottom right instead of top left). The movers took it to a repair shop and they said that the circuit board of the display panel had a failure. Does this make sense?
    Top Expert:
  • Vizio Master
  • 75,157 Answers
Do a factory reset to this TV. Refer its user manual for details.
Posted on May 08, 2013
Testimonial: "This didn't help. Thank you though!"
Hisense tv picture is upside down, it was working fine
If the picture on the TV is upside down, press the Menu button, then check the following:
? If the Menu is displayed correctly the problem would be a setting within the external source or a signal issue. Please contact the manufacturer of the external device for further assistance.
? If the Menu is also displayed upside down, then the TV will require service..
Nov 08, 2016 | Hisense Televison & Video
How do I fix my screen that is upside down on a Magnavox led TV
This has to be a display that can be mounting in several positions. Under the set up/settings menu there should be a display options area for which way it displays. Strange for a TV but there are TVs that can display horizontal or vertical.
Jan 18, 2015 | Magnavox 40ME324V 40" LED TV 1920x1080,...
MY SCREEN DISPLAY WAS ROTATE UPSIDE DOWN
open its sevice code.go to picture menu then come on contrast & press this code 9735.tv wil go to service menu here u can do what u want
Sep 04, 2013 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
LC-37SH12U picture is upside down
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Nov 06, 2017 | Televison & Video
Ps3 screen margins too wide for tv display
Try holding your power button on your ps3 down till it blinks.(not your main power switch on back of console) I do believe if correct, this should reset your ps3 resolution to an auto set for best display on your tv. It may pop up with a message on resolution, but that should work. I had similar problems and that worked for me.
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
Sony lcd projection tv vertical adjustment KF-50E200A
Try changing the settings for the video formats, widescreen, regular, and all that. There are angle mirrors in the back of the tv that direct the projected image on the screen. The mirrors are positioned such that if, says, a piece of a metal bracket or something falls down inside the projection area, it'll fall right against the projection lens and block the image. Open up the back of the tv and follow the light path from the screen backwards to its source and make sure there's no debris in the projection path.
Sep 17, 2009 | Sony KF50E200 TV
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
Picture settings
You should go to the menu and look for the "Mirror" settings, change the vertical to bring it rightside up, however if it is also backwards (horizontally) change the horizontal "Mirror" there is an option of turning on either both or each separate option. I assume though that you will probably just have to change the setting to H&V Mirror.
Apr 07, 2009 | Hitachi CP-S235 Multimedia Projector
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Vizio XVT3D474SV 47 in. 3D LCD TV Logo
169 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
