Question about AVC Computers & Internet
328364nc hp heatsink
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
Hp 2730p fan noise
Laptop Fan noise:
This seems to be a common problem with laptops over a couple of years old. Dust gets trapped in the copper fins and the fan of the CPU heatsink and reduces the efficiency of the cooling, which results in regular power off's by the laptop as it gets over it's upper temperature setting. The fix is relatively easy, just remove the heatsink unit, blow it clean with compressed air, clean the old CPU heatsink paste off with isopropyl alcohol (IPA) and spray a thin film of heatsink paste on the CPU.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 12, 2011 | HP EliteBook 2730p Notebook
Iam using HP Desktop D530 when i open some programmes but processor fan runs so fast and loud 2 gb ram in my pc and hard disk is 20 gb how can i reduce noice of fan ?
To reduce the fan noise, open the PC Case and clean the fan. Also, proper ventilation keeps the system cool and the fan runs at lower speed.
Hope this helps!
CreativeTECH
Dec 11, 2010 | HP Compaq d530 Small Form Factor PC...
I need a cpu fan for the HP Media M370N
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150086 this is a compatible cpu fan and heatsink or you can search ebay and find the oem fan and heatsink quite easily
Sep 23, 2010 | HP Media Center M370N (DM163A#ABA) PC...
Where does one source a replacement cpu heatsink
Any computer store or www.partselect.com may have it or kijiji or ebay
You have this vast expanse call the world wide web (WWW)
Happy searching
Jul 31, 2010 | HP Pavilion (F2111-60950) CPU Heatsink &...
Dear Sir sir i have hp desktiop pc and i have
You need to remove the Heatsink from the CPU and re apply heatsink compound to both the CPU and the heatsink then replace the heatsink onto the CPU. the reason for the overheating and shutdown is that the connection between the heatsink and the CPU has become "Aged" and no longer transfers the heat like it should
Jul 20, 2010 | HP Compaq d530 SFF PC Desktop
How to change heatsink for hp compac dc7800p
hi,
buy the same heatsink that fit into it..theres a 3pin socket into it...pin that socket into desired connection..thanks
Nov 30, 2009 | HP dc7800p Business Desktop Small Form...
How to replace CPU on HP 6735s
Most likely from the back (the underside) where the fan/s are located. You will need to remove the fan/heatsink to get to the CPU. The CPU is locked in place with a zero insertion socket, you need the turn the locking screw 90 degrees to release the CPU.
Be careful when you insert the new CPU, there is a notch that indicates the orientation of the CPU to the socket.
After installing the CPU don't forget to put some heatsink compound on the CPU before installing the fan/heatsink.
Feb 12, 2009 | HP Compaq 6735s Notebook
The cpu heatsink clip has come apart, would like to know how to fix. the model is hp pavilion 734.uk
http://cgi.ebay.com/Intel-Socket-478-HEATSINK-RETENTION-BRACKET-Module-ONLY_W0QQitemZ170211538308QQihZ007QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That's what usually breaks if you have a 478 pin cpu. Should be available in any computer shop. If the actual metal bracket on the heatsink broke you will have to buy a new fan/heatsink. Both solutions are cheap.
Apr 24, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top AVC Computers & Internet Experts
David Payne
David Payne
Are you an AVC Computer and Internet Expert? Answer questions, earn points and help others
