Question about Vacuums
How to take apart the switch and rocker arm assembly on my electrolux canister
The switch is not engaging and I have the canister open. Rocker arm, spring and tubing fell out. Which parts do I need and how to reassemble?
  • Julie kis May 09, 2013
    Let me be more specific. I see that the rocker arm is broken. This is an old Electrolux LE, over 20 years. The pieces of it and a spring fell out when I removed the switch assembly. I have ordered a new rocker arm but am not sure how to reassembly everything when I get it. Wish there was a drawing.
3 Suggested Answers
  • 430 Answers
SOURCE: My Electrolux Epic 6500 SR will not turn off by
WOW !!! Finally You are dead on, absolutely 100%.... good work!!!.
Get only a genuine new switch button with spring from an AERUS Electrolux dealer and reinstall.
Then carefully reassemble the entire body and wiring harness.
Congratulations getting there.... you rate as an honorary technical genius in my book,...Your wife should be bragging about you to her friends. I am genuinely impressed and I`ve been fixing these since 1990. I bow in your presence.
PS while youre in there, check the rocker for evidence of fatigue, it is the more common issue
Posted on Nov 01, 2009
Testimonial: "Thanks for your speedy reply and diagnosis. I will get the operator button and also the rocker part while I am at it. "
  • 694 Answers
SOURCE: I have a Electrolux 2100 vacuum. I have found and
As you're looking at the switch side, the short end of the spring clips over the right end of the rocker. The long end clips into the rectangular hole at the other end of the switch housing.. The rubber piece will point to the rear.
Posted on Apr 18, 2011
How do I replace the rocker arm in the off and on switch of the Electrolux canister vacumn model 2100
This is something that can be very difficult to explain, much less perform without prior knowledge of this particular model.
With 30 yrs. experience, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
mickeymackmark1@yahoo.com. Hope that helps! Mick
Mar 09, 2015 | Electrolux Vacuums
Where is the reset on electrolux EL8505?
it may be the rocker arm located under the the switch.They are plastic and break,best bet is to take it to a repair shop Not too expensive of a fix
Sep 01, 2014 | Electrolux EL8505A Bagless Upright Vacuum
I think it's the on/off switch since it doesn't feel right. But I would like to diagnose it before I bring it in for repairs. Can I replace a control switch myself? I can take apart anything!
It sounds like the Rocker Assembly has cracked inside your switch. When they break it's usually in the "Off" position.
So this is how you take it apart:
Remove Hose
Remove Bag
Now stand the vacuum up and peel back the bumper guards on the left and right side of the vacuum. Peel them back roughly 6 inches and pull straight up on the bumpers. This should release the side of the machine.
When doing the other side be careful in doing so because once you release that last bumper, your vacuum will be ready to disassemble.
When you remove the bumpers place your vacuum wheels up. Pull the cord out roughly 3 ft, just for slack. Now you should be able to release the bottom of your vacuum.
When you lift off the bottom of your vacuum (wheel side) the front cover and the bag compartment will come with it. Just be careful. There will be about 4 wires. Just unclip the wires from the bag compartment. That way you can place the front of the vacuum at the back of the machine to give you more room to work with.
When removing the bag compartment, there will be a clear hose that plugs into the lower corner of the compartment. That will just slide off, but be sure when you reassemble that you connect that clear hose back on your vacuum will show a full bag indicator.
Now once you have the front cover and bag compartment out you should see the underside of your switch. There will be 2 to 4 screws. Remove them and the cover will release your switch from the underside.
When your switch comes out you will have to push the retaining clip on the top of the switch to remove the cover. Once you do that you will see 2 slider switches with a broken rocker in between them. There will be a small spring attached to this rocker so pay attention on how it goes back on the rocker.
Go to your local Aerus Electrolux with your rocker and tell them you want a replacement rocker. It should be under $10.00 and once you do that, just reverse these steps.
Good Luck!
Nov 21, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I have a Electrolux 2100 vacuum. I have found and repaired the broken rocker on/off switch. What I need to know is where does the spring with the rubber tube inside it get connected? Thanks Alan
Apr 17, 2011 | Electrolux Vacuums
Vacuum cleaner won't turn on. "On" switch is broken, but it has been turning on by just plugging it into a socket. Plug symbol now lights up on tank and machine doesn't turn on at all. Is it a...
It sounds like you may need a new switch rocker arm. If so this is not an expensive repair. I would suggest you takeit to a reputable vacum shop for repair.Chris
Feb 20, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Need to know how to open the canister of my Electrolux Ambassador vacuum to replace the switch
If you switch still"clicks" you need a switch rocker, if it no longer clicks you will need a new switch button. You will get best results with the genuine button from an AERUS Electrolux repair shop
There are a set of body keys under the bumpers on this vac which slide forward to the front door with a set of pliers. They are locking one way so reinstall same direction . Examine the front hinge are before opening the vac. Once removed the panels will open like a **** shell from back to front. You will need to be careful realign all pieces in their tracks.
The switch is best accessed by removing only the bag cage. The housing will lif up without detaching wiring and the rocker and switch button will snap out as separate pieces. Test before reassembling and when done if the entire body does not assemble easily stop and check your alignment. It will click together like Lego pieces when you have it right.
Post back to advise how you make out
Nov 03, 2009 | Vacuums
My Electrolux Epic 6500 SR will not turn off by pressing on the switch button. I took it apart and removed the switch assy. I can maunually turn it off & on by pressing the rocker arm on the switch...
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Replace switch on electrolux 2100
The 2100 is an older model which is prone to rocker switch failure. What you see outside is only a switch button. Underneath is a plastic rocker which sits in a grove and pivots back and forth to activate the on off switch.
If you push the switch down and there is no audible "click" you Likely need the rocker itself, especially if you tip the vac upside down and shake it and hear a piece rattling inside or find a broken narrow plastic finger about 1/2" inch long when opened.
However if it clicks and works every 3-5 times,the rocker is fine and you will need the spring mechanism and switch button which you can see form outside.
To remove either the process is the same.
Separate the body by opening the bag cage and pulling the two bumpers forward with a set of pliers. They are locking keys. Once removed, the rear housing will drop off allowing the vac to hinge open back to front. Do this with the vac laying upside down and observe the hinge section of the front bag door .DO NOT REMOVE THE MOTOR. You will need to clip all these componnets back together to reassemble and slide the bag chamber back to seat against the motor with the motor housing engage in the ribbing of the vac side walls.
With the vac open you will only need to remove the spring loaded bag lockout switch and the bag housing it sits on, not the motor or rewind..
Once removed there will be 6 chrome philips screws visible. These hold the top trim on the front of the vac and the front ones hold the on off switch into its housing. At the very front will be two screws going through a black or whitish switch housing. That housing will lift out with wires attached to reveal the switch rocker, etc,. This portion will lift back and out at about 45 degrees of the inner housing, as a unit. The switch button sits atop the rocker via two end tabs and will pop off the housing to reveal if the rocker itself has a broken "finger" or if the button has a weak spring.
The suspect spring is not the coil rocker spring but the thin U shaped spring on the underside of the switch button. Remove the rocker spring with a pair of needle nose pliers.and examine the rocker comparing to your new one.Use more vaseline on the new rocker and if you have it reinsert the clear flex plastic into the coil spring. If not disregard.
Re-installation is the reverse order, tuck switch back in at 45 degrees from back to front.
Pay special attention the the rubber seal at the back of the bag cage.
If anything is misaligned in this body you will fight to reassemble. Don't fight it , back up and look at your work. When and ONLY when it is perfect it will realign and click together like a lego set and the keys will slide in perfectly
You can and should test the vac before reassembling the whole body, simpley slide your hand under neath and activate the switch, with a bag inside the vac.
See now, wasn't that EASY???????
Please post back to advise how you make out. Its a 7 minute process worth $25 for a good tech. A bad tech will spend half a day trying to figure this one out but just go slow and follow the instructions and you will do fine.
Oct 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Twenty year old Electrolux canister swith stopped working
What switch? If the switch is inside the tank, open it from the underside with 3 screws.
Nov 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
