Surround sound Trying to hook the receiver up to the tv for surround sound but I don't know where to put the RCA jacks.
  • 38 Answers
You should have the RCA TV plugged into the OUT plugs on the TV and just plug them into the IN on the back of either the ld tv or cd inputs on the receiver then plug it in and set the setting on the receiver to the same RCA you plugged it into then turn your TV and receiver volume up and enjoy.
Posted on May 08, 2013
  • 3 Answers
SOURCE: technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Posted on Jul 12, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
mlapres
  • 757 Answers
SOURCE: how to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Posted on May 08, 2009
jomabug76
  • 1148 Answers
SOURCE: no surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
Posted on May 15, 2009
mlapres
  • 757 Answers
SOURCE: Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Posted on Dec 23, 2009
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
How do i hook up mt audio speakers to my tv for surround sound? klh 403
If I understand correctly form your question,you can not hook them unless your TV has 5.1 surround sound amplifier built in...Does it ? I doubt so..
in order to get a surround sound from your TV you need a 5.1 /7.1 DVD/Receiver and you can connect your TV to listen it thru Receiver ..Here is how you can do it..
** connect "Audio Output " as either :"2xRCA jacks"or "Optic cable output" or "HDMI "connector " of your TV ,
** to "RCA input jacks " or "Optic Cable input"
or if you have "HDMI input" of your DVD/ Receiver
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..your Tv sound are on the
DVD/receiver as SURROUNDING SOUND .
By this means ,whatever you watch on the TV
will come thru your
Receiver
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 06, 2011 | Audio Players & Recorders
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble...
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
May 26, 2011 | Nintendo Wii Console
Can't figure out why there isn't an out on my curtis mathes for surround sound with sub. When we bought the "tv" from a friend we thought it was a "flat screen tv" it says on...
In most cases the TV is used just as an input device, and they frequently have no output jacks. Usually the TV is hooked up as part of a home theater system, and is used as a video monitor while the sound is taken care of by a receiver or amplifier. The sound comes from the video source (DVD player, set-top box, etc.). Some TV sets have audio output available, but it sounds like yours doesn't. If you want to have surround sound, you'll need to invest in a receiver and speakers.
May 05, 2011 | Televison & Video
Dec 23, 2009 | Sony STR-DE575 Receiver
I have a 42 inch sanyo tv I am trying to hook up saround sound or just extra speakers
Extra speakers without having the external speaker jacks in the rear is definitely a NO NO. The surround sound is used by connecting the RCA jacks from the TV that say Audio Out to the surround sound audio input on the receiver.. The RCA cables are cheap, you can get them at Home Depot ect....
Nov 27, 2009 | Sanyo Televison & Video
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Trying to install surround Sound with my TV
you can still hook it up using the correct methd, for the best method consult an in home surrouns team. or an electriconic provider.
Jul 14, 2008 | Panasonic Televison & Video
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
41 people viewed this question
 Grubhead
Grubhead
