Question about Vehicle Parts & Accessories
96 accent ignition switch std trans no airbag
The key will not stay in the on position. do I have to replace the whole cylinder ? the s
whole cylinder is expensive. I have seen universal keys parts inexpensive but can not figure out how to seperate the keyed portion from the rest of the cylinder to replace.
You have to replace the cyl. Out bc of the springs in cyl.
Posted on May 11, 2013
  • 8 Answers
SOURCE: I have a 96 saturn SL2.. one morning key wouldnt turn.. took ignition cyclinder out within 20mins.. been trying to put new one in for 2 days! What am I doing wrong
Insert key into new cylinder.Rotate key counter clockwise inside cylinder. install. If problem still exists, try turning clockwise to different position
Posted on Feb 22, 2012
patch1621
  • 55 Answers
SOURCE: 2012 Kia forte Koop key in ignition locked in place, will not turn
try pressing on the brake and holding, making sure car is in correct gear.
but pressing on the brake and holding, then try to rotate steering wheel!
Posted on May 21, 2012
george_karas
  • 211 Answers
SOURCE: Turn ignition key to start 2003 FX45. All electrical systems seem to be working but starter wont turn over. Turn key to off and then back on again and car starts. Battery and charging system checked
low battery, bet wire conection solenoit bet conectivity.
Posted on Aug 09, 2012
cassdvd9
  • 33 Answers
SOURCE: 2000 plymouth neon...ignition locked up. Key has
SOMETIMES ON OLDER CARS YOU CAN PUT THE KEY IN AND TURN THE STEERING WHEEL TO UNBIND THE LOCKIN MECHANISOM ALSO MAKING SURE THE TRANSMITION IS COMPLETELY IN THE PARKING POSISTION. SO JUST JIGLE THING AROUND TO SEE IF IT WILL RELEASE. HOWEVER IT MIGHT NEED TO BE REPLACED OR KEY IS SEVERLY WORN AND IN THAT CASE IT NEEDS TO BE REPLACED. GOOD LUCK
Posted on Nov 22, 2012
SOURCE: Key won't turn in ignition and the wheel is locked up
Maybe you need to find the right key 'cause this one could be the wrong one, or, worn out. Wiggle the wheel more. I know you wiggled it in the vid. Wiggle the key in and out. Try the second copy of the key.
Posted on Apr 10, 2013
I have a 96 Dodge Ram 5.2. I replaced the ignition switch and cylinder. After replacing the vehicle starts but won't turn to auxiliary,the key won't come out and the truck won't go into gear.
When you remove the lock cylinder, the ignition switch needs to be in the run position, and you need to put the new cylinder in the run position before installing it. It may be possible to get the cylinder into the switch housing in a different position, which may be what happened with yours. See the YouTube video at https://www.youtube.com/watch?v=xN88TceP12c
Jan 20, 2016 | Dodge Cars & Trucks
Changing out ignition switch
    Remove the Ignition Switch
  1. Disconnect the negative battery cable with a socket or box wrench. Pull the airbag fuse from the driver's side fuse panel using the fuse removal tool found on the panel. Disable the theft-lock system on the radio.
  2. Remove the instrument cluster by removing the bezel screws with a screwdriver and prying the bezel off with a prying tool or flathead screwdriver.
  3. Remove the two screws holding the ignition switch in place with a screwdriver.
  4. Push the ignition switch about one inch toward the front of the vehicle so that it will clear the mounting bracket. Lift the switch up and out from behind the instrument panel.
  5. Disconnect the electrical connectors from the ignition switch. Put the key in the ignition and turn it the Run position.
  6. Press the spring-loaded pin on the side of the ignition switch with a small screwdriver. Pull the lock cylinder out by the key.
  7. Install the New Ignition Switch
  8. Place the ignition key in the new ignition cylinder and push the cylinder into place in the ignition housing. Turn the key to the off position and remove it.
  9. Connect the electrical wires to the back of the ignition switch.
  10. Put the switch assembly in position in the cluster and install and tighten the two screws with a screwdriver.
  11. Install the instrument cluster bezel and attach the two screws with a screwdriver.
  12. Replace the airbag fuse in the driver's side fuse panel. Connect the negative battery cable with a wrench. Enter the code for the Theft-lock system into the radio.
Mar 09, 2011 | 2002 Oldsmobile Alero
Trying remove the ignition in toyota avalon 2000
TO REMOVE THE IGNITION SWITCH FIRST TURN OFF RADIO.AND DISABLE AIRBAGS BY DISCONNECTING NEGATIVE BATTERY CABLE WAITING 20 MINUTES UNTIL AIRBAGS DISCHARGE.TO REMOVE IGNITION SWITCH PLACE THE IGNITION KEY IN THE ACC POSITION. REMOVE THE STEERING WHEEL AND REMOVE THE STEERING COLUMN COVERS.DISCONNECT THE IGNTION SWITCH ELECTRICAL CONNECTORS.REMOVE THE SWITCH RETAINING SCREWS THEN PULL THE SWITCH FROM THE LOCK CYLINDER HOUSING.IF YOU TRYING TO REMOVE THE LOCK CYLINDER WITH LOCK CYLINDER IN ACC POSITION. USE A SMALL SCREW DRIVER OR PUNCH. DEPRESS THE LOCK CYLINDER RETAINING PIN THEN REMOVE LOCK CYLINDER. TO INSTALL NEW LOCK CYLINDER. DEPRESS THE RETAINING PIN AND GUIDE THE LOCK CYLINDER INTO THE HOUSING UNTIL THE RETAINING PIN EXTENDS ITSELF BACK INTO THE LOCATING HOLE IN THE HOUSING.
Mar 01, 2011 | 2000 Toyota Avalon
How do you remove the ignition switch part to replace
FIRST OF ALL TURN OFF RADIO TO KEEP FROM LOCKING IT OUT.THEN DISABLE AIRBAG.DISCONNECT NEGATIVE BATTERY CABLE.WAIT 20 MINUTES.MAKE SURE TURN THE STEERING WHEEL SO THAT BOTH WHEELS POINTING STRAIGHT AHEAD.TURN IGNITION SWITCH TO LOCK THEN REMOVE KEY.TO REPLACE THE IGNITION SWITCH.REMOVE THE INSTRUMENT CLUSTER.REMOVE THE 2 SCREWS SECURING THE IGNITION SWITCH.PUSH SWITCH 1 INCH STRAIGHT BACK TO CLEAR THE MOUNTING BRACKET THEN LIFT OUT.TO REMOVE LOCK CYLINDER PUT KEY IN SWITCH TURN TO RUN POSITION THEN DEPRESS THE PIN WITHDRAW THE LOCK CYLINDER.
Jun 30, 2010 | 1999 Oldsmobile Alero
Location of ignition switch on 2006 gmc envoy
PATH: Chassis Electrical > Instruments & Switches > Ignition Switch > Removal & Installation Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disable the airbag system, as outlined in the Chassis Electrical Section.
  3. Remove the hush and knee bolster.
  4. Remove the steering column trim covers.
  5. With the key installed, turn the key to the RUN position.
  6. Install a hex wrench into the hole on top of the lock cylinder housing. Push down on the hex wrench to release the tab on the lock cylinder inside the lock cylinder housing.
  1. Slide the lock cylinder out of the lock cylinder housing.
  2. Disconnect the passlock and key buzzer from the lock cylinder housing.
  3. Insert into the lock cylinder housing
Release the tabs on the ignition switch using ignition switch connector release tool J 42759
  1. Pull the ignition switch out of the lock cylinder housing.
  2. Disconnect the connector from the ignition switch.
To install:
  1. Verify the alignment of the gear in the ignition switch. If gear is not in position shown, turn gear in ignition switch until you reach the correct position.
  2. Use a screwdriver to rotate the lock cylinder housing gear counterclockwise until it hits a stop. In order to reach a stop while rotating the lock cylinder housing gear you MUST push and hold in the solenoid on the electric park lock.
  3. Connect the connector to the ignition switch.
  4. Insert the ignition switch into the lock cylinder housing. The tabs on the ignition switch MUST be seated inside the lock cylinder housing for proper installation.
  5. Use a screwdriver to rotate the lock cylinder housing gear clockwise to the start position—allowing it to spring return into the RUN position.
Use a screwdriver to rotate the lock cylinder housing gear clockwise to the START position
  1. Align the lock cylinder and install the lock cylinder into the lock cylinder housing.
  2. Connect the passlock and key buzzer into the lock housing.
  3. Install the steering column trim covers.
  4. Install the hush and knee bolster.
  5. Enable the airbag system, as outlined in the Chassis Electrical Section.
  6. Connect the negative battery cable.
Oct 12, 2009 | 2006 GMC Envoy
!995 Honda Accord won't stay running unless it is in the starting
your starter switch is bad. it is on the coloum. needs to be replaced.
Aug 14, 2009 | 1992 Honda Accord
Replacing the ignition switch in a 96 ford mustang cobra svt
Follow these steps carefully. this will help you achieve this replacement.
  1. Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower steering column covers by unscrewing them.
  2. Remove the steering wheel by lifting off the center cover, disconnecting the horn wire and removing the retaining nut and washer. Make a mark on the steering wheel spline and the wheel itself so you can line it back up precisely. Pull the steering wheel straight back to remove from the shaft.
  3. Take off windshield wiper and turn signal switches by pulling them off as you did the steering wheel and disconnect the wiring. Slide the spacer sleeve off of the steering column.
  4. Unscrew the ignition switch mounting screws. Pull out the ignition switch. Disconnect the wiring connector from back of the ignition switch. Simply loosen the tabs and pull it out.
  5. Insert your key into the ignition. Turn the ignition switch to the locked position. Depress the retaining pin with a small screwdriver and turn the key to the Off position to free the cylinder. Once it is free, turn the key to lock position and remove the key and key cylinder.
  6. Install your old key cylinder into the new ignition switch assembly. Make sure the contacts in the cylinder and assembly line up. Reattach wiring to ignition switch, slide it into place, screw in mounting screws and reassemble steering wheel and switches.
Jun 17, 2009 | 1996 Ford Mustang
96 ford windstar ignition probs
the ignition switch is the electrical part behind the lock cylinder where the key goes in.
Ignition Switch Lock Cylinder
Lock Cylinder Functional
Removal
  1. The following procedure applies to vehicles that have a functional ignition switch lock cylinder (11582) and keys. If the key numbers are known, the correct key can be made. Disconnect the battery ground cable (14301). For additional information, refer to Section 14-01 .
  1. Turn the ignition switch lock cylinder to the RUN position.
  1. Place a 3.17-mm (1/8-inch) diameter wire pin or small drift punch in the hole in the steering column shroud under the ignition switch lock cylinder. Depress the retaining pin while pulling out on the ignition switch lock cylinder to remove it from the housing of the steering column.
Installation
  1. Install the ignition switch lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the ignition switch lock cylinder into the steering column housing. Make sure the ignition switch lock cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the retaining pin of the ignition switch lock cylinder to extend into the hole of the steering column.
  1. Using the key, rotate the ignition switch lock cylinder to make sure of correct mechanical operation in all positions.
  1. Connect the battery ground cable.
Ignition Switch Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the upper steering column shroud (3530) by removing the four or five self-tapping screws. Remove key release lever (3F527) (if equipped).
  1. Remove lower steering column shroud.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition switch lock cylinder (11582) to the RUN position.
  1. Remove the two screws retaining ignition switch (11572).
  1. Disengage the ignition switch from the actuator.
Item Part Number Description 1 11572 Ignition Switch 2 — Ignition Switch Lock Cylinder Housing 3 — Slot in Lock/Column Assembly A — (Part of 11572) Pin B — Alignment Mark
Installation
NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and key release lever (if equipped).
Feb 27, 2009 | 1996 Ford Windstar
Car was stolen broke the ignition
REMOVAL
  1. On models equipped with airbag, disarm airbag as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
  2. On all models, disconnect battery ground cable.
  3. Remove ignition switch as described under STARTING AND CHARGING SYSTEMS/COMPONENT REPLACEMENT AND REPAIR PROCEDURES/IGNITION SWITCH.
  4. Remove key light case from lock body, if equipped.
  5. On 1989 Accord models, place ignition lock cylinder in the ACC position.
  6. On except 1989 Accord, place ignition lock in the I position.
  7. On all models, position suitable punch into hole on lock cylinder housing and depress pin, then remove lock cylinder from housing.
INSTALLATION
  1. On 1989 Accord models, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the LOCK position.
    2. Rotate key until it is almost at the ACC position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to ACC position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. On except 1989 Accord, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the O position.
    2. Rotate key until it is almost at the I position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to I position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. Install ignition switch and connect battery ground cable.
SRS wire harness is routed near the ignition switch.
CAUTION:
  • All SRS electrical wiring harnesses are covered with yellow outer insulation.
  • Before disconnecting the SRS wire harness, install the short connector on the airbag.
  • Replace the entire affected SRS harness assembly if it has an open circuit or damaged wiring.
IGNITION SWITCH
  1. Remove the steering wheel, then remove the steering column covers.
  2. Disconnect the 7-P connector from the under-dash fuse box.
  3. Insert the key and turn it to "0."
  4. Remove the 2 screws and replace the base of the switch.
Feb 13, 2009 | 1992 Honda Accord
Vehicle Parts & Accessories Logo
97 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
