Question about Frigidaire FTF530FS Front Load Washer
My frigidaire front load washer starts...then quits...
I start a load of wash..it fills and the dial will advance, but then it quits, usually about half way through the cycle. Sometimes it doesn't even make it half way. The power light stays on, but the dial won't advance. The washer was doing the same thing about a year ago (when we had only owned it for a few months and it was still under warranty) and the repairman replaced the timer. Now it is doing the same thing...of course now I believe it is out of warranty. Could this be the timer again...and if so, what would cause it to fail again so soon? If you do think it is the timer, is this something we could replace ourselves? (We have the old part with the box and part number) Any help will be greatly appreciated!!! Thanks!!!
  • 3 more comments
  • 4dugnlee Aug 12, 2007
    We checked the filters on the hoses in the back of the washer...we also took the pump off to see if those hoses were plugged. We did a load this morning and the dial only advanced 2 clicks. If we put our ear up to the dial, we could hear a fast ticking sound but it wouldn't advance any further. We manually advanced the dial throughout the rest of the cycle.
  • rlt2 Jul 24, 2008
    I have had the same problem. My timer was replaced under warranty 2 times then once by me. The problem seems to be the small drive motor in the timer can't turn the the complex plastic timing wheels. I wish I could find a source that would provide replacement motors instead of $125 timers. Anyone know of such a source?
  • Mister160 Jul 30, 2008
    I bought the Frigidaire LTF530FS model in May of '07. The exact same problem would occur where the timer would stop and not finish the cycle. I had the Timer replaced in August of '07 under warranty, but the same problem has started again and of course it's no longer under warranty. If I stand there and turn the Timer through the cycle, the washer still functions. I noticed that a pump problem was mentioned. My drain pipe is almost near the basement ceiling so it's pretty high. If I raised the machine could this solve my problem?
  • Anonymous Aug 27, 2008
    1) My washer won't wash on the cold setting. Also, it wont complete a wash, it stops at the rinse cycle because the cold water is not working. The hot water works fine. Doesn't dispense the bleach or fabric softener either.
    I've checked the hoses, the water inlet screens on the back of the machine. Everything is fine.
    2) The timer stops before the rinse cycle. I can advance it manually but it doesn't rinse because there is no cold water.
    ANY HELP WOULD BE GREATLY APPRECIATED!
  • Anonymous Dec 14, 2008
    Cold water not working. Stalling rinse cycle if washing with warm or hot. Will not start on cold/cold. Advancing dial starts machine but no rinse
    Novelist:
    Champion:
  • 244 Answers
Yes it could be but also it could more than likely be your pump not letting water out or not letting enough water out which stops the cycle try doing aload when it stops turn dial to empty and if it spins then your pump is faulty needs replcing thats the more common fault
Posted on Aug 12, 2007
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire gallery washer
Do you mean that after it fills up with water you have to advance the dial for it to start working?if that is so Check the water level switch.Otherwise you may have aproblem with the timer.
Regards
Please rate this solution
Sep 24, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
476 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
