Question about GE Refrigerators
200d4854g018 motherboard why is frezzeing in the frezze and doesen't cold in refrigerator?
altec1105
  • 68 Answers
SOURCE: frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Posted on Jun 23, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Refrig is frezzing
Your model a WR49X10091 Electric Controled Air Damper between the freezer and the fresh food section. Sometimes they get stuck open and sometimes the electric motor malfunctions. Most times a little frost will hang them up. Until we can see that we can get this part opening and closing properly we will need to unplug your refrigerator and examine the inside of the back of the freezer behind the rear panel to see if there happens to be frost stopping the door from regulating temperatures. I will be here waiting for your comments and results. Let me know what you find, Thanks, Sea Breeze
Posted on Sep 12, 2009
  • 79 Answers
SOURCE: food is frezzing up in refrigerator
Normally if the dial control is in the refrigerator section and is marked A,B,C,D then A will be the warmest setting. If the dial is marked 1,2,3,4 then 1 is the warmest setting. Hope I was of help to you!!
Posted on Nov 29, 2009
  • 117 Answers
SOURCE: true cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Posted on Jan 08, 2010
heatman101
  • 43501 Answers
SOURCE: samsung refrigerator and frezzer do not get cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 24, 2010
Freezer keeps frezzing with ice and the refrigerator is not keeping cool
I'm not a refridgerator repairman but when coils get covered with ice it is usally because the refridgerant (freon) is low. You will need a liscened repairman to fix it. If you try to do it yourself, you will be calling a repairman anyway and it will cost way more to fix it then to have repaired.
Nov 20, 2012 | Kenmore Refrigerators
Top frigerater is frezzing
if you look in the bottom of the fridge there should be a dail from one to
5 ajust to your disired coldness if not try http://www.applianceaid.com/frig_notcold.html
Mar 18, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a 2004 Trailblazer and my rear a/c starts out blowing cold air but gets warm shortly after but the front a/c keeps blowing cold air all the time???? what could cause that ????
Just a little low on freon can make it get too cold and it freezs if you in position to check the freon level you'll find with the system on high and the engine reved up the low pressure is below 25PSI. fill it to reved up is above 25 and your problem will go away. Low on freon will make it cold enough to frezze up and then warm up as the air does'nt go though the ice. it'll work good as you start up till it frezzes and after it's stopped up with ice it blows warm (it's really too cold). the more freon in the system the warmer it'll all blow because all the pressures are higher and it's the difference in pressures that make it cold.
Aug 24, 2011 | 2004 Chevrolet TrailBlazer
It frezzing up not getting cold i see the ice inside the window unit when i take off the filter
Either your not getting enough BTU's across
the evaporator ,because the system has a refrigerant
leak & it boils off too soon & freezes the coil or the
fan isn't working
Could have a bad thermostat but I doubt it
Jun 23, 2011 | General Electric AEQ12DM Air Conditioner
Hi we have a frige frezzer which is 6x3ft about 10 years old and its not frezzing or getting cold but the light and fan are still working?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | De Dietrich Refrigerators
Stand up cooler is frezzing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 14, 2011 | Refrigerators
The upper area were is not frezzing is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sgasgaiyl
Jul 15, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Frezzer not frezzing
Jun 23, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
