Question about Toro 52" Cut Wide Area Walk Behind Lawn Mower
Toro repair manuals
7.5 amp Fuse blows when pto blades are engaged. Wiring appears sound.
    Problem Solver:
  • 4 Answers
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
Posted on May 07, 2013
  • Justin Prater May 07, 2013
Even with the mower not running when i pull the switch to engage deck it blows 20 amp fuse
Kelly, ray g. nailed it, First be sure it is only to be a 20 amp fuse, The wires to the clutch that drive the deck will be broke or bare shorting out on each other or on metal, wire are quite commonly broke by the clutch plug or close by. what you can do is carefully follow the wire from switch through the system and look for damage or bare spots, pay special attention when wire runs through frame/body holes and any where it could rub on metal or moving parts. Check the attached links,instruction and guides,4th link see Randy T. reply in forum, has good test method for your problem. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Craftsman 917 273631 Fuses keeping blowing when blades are engaged
CC1042 with Kohler Keeps Blowing Fuse when PTO Engaged
Blowing Fuses
265 blowing main fuse when engaging PTO
Apr 25, 2016 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
GTH2548 mower starts but when I engage blade, it blows the fuse.
Probably the electric PTO shorted to ground. Unplug the connector at the PTO clutch and re-test if it no long blows the fuse then the clutch is bad; otherwise, there is short to ground in the wiring between the switch and that connector.
Aug 08, 2014 | Garden
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Husqvarna Yth 180, the lawn mower shut off when I engage the blades to cut grass. I blows the 20 amp fuse near the wire harness
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Jul 13, 2009 | Husqvarna Garden
Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
May 24, 2009 | Oregon Scientific Electric PTO Clutch for...
The blades stop and the 20 amp blowes on My YTH
Hello:
This Sounds like a Bad PTO.
The Following is a Basic File I Made for Checking the PTO (Blade Engagement). The Most Common Cause for this Problem is the PTO Ground. A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO. Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire. Clean the PTO Ground and All the Connections for the PTO Wiring Harness. If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
Toro 52" Cut Wide Area Walk Behind Lawn Mower Logo
259 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
