Question about Snapper Garden
Snapper belt lx1642
Blade turns off my itself
  • 138 Answers
SOURCE: broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Posted on Aug 15, 2009
bbreton
  • 437 Answers
SOURCE: shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Posted on Oct 29, 2009
wireguy212
  • 1627 Answers
SOURCE: snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Posted on Nov 03, 2009
  • 16 Answers
SOURCE: Snapper Zero Turn mower. Blade will not engage. Any suggestions?
I am not sure what type of blade engagement mechanism you have (ex. clutch, tensioner/idler pulley, etc...) but make sure that the blades can spin freely with the belt taken off of their pulleys. It could very well be that one of the pulley bearings is seized.
Posted on May 07, 2010
  • 3074 Answers
SOURCE: hi, i have an snapper riding lawn mower model
http://www.ehow.com/how_6402951_change-snapper-mower-belt.html
Posted on Apr 03, 2011
Snapper 1642h rider does not self propell belt is intact
The belt may worn. Check to see if there is slack in belt. You did not say if blades were turning. Also what is the complete model number. Number is not found in online manuals. Thanks and let me know.
Jul 04, 2017 | Snapper Garden
My snapper yard cruiser Lou runs drives turns left right but when I pull the PTO switch the blades will not engage it's a snapper z yard cruiser with kohler engine
There are limit and safety switches in the wiring circuit. When it registers a back-up it disables the blades or turns the engine off. Find the backing switch and try to temporary bypass it
Jul 10, 2015 | Snapper Garden
Mower belt diagram
Snapper Mower Manuals with belt info and diagrams can be found at:
Find Your Snapper Manual Parts Lists
http://www.snapper.com/us/en/support/manuals
Aug 12, 2014 | Garden
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Mower blade not engaging
Check your belt. May broke, off, slipping.
Frayed traction drive belts on a zero turn, joy stick snapper. How do I change the belts.
take it to someone that knows these... they aren't easy or easibly explainable !!!
Sep 30, 2013 | Oregon Scientific Oregon Gator Mulcher...
How can i get more blade speed from my 355z snapper
what for you have 26hp. what are you trying to cut. check your blades are sharp. and dont expect it to act like a mulcher.
Jul 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
May 06, 2010 | Garden
Garden Logo
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
