Question about JVC Audio Players & Recorders
UX-DAB11 Display Hi, The display on the system does not work, is there a way to reset it?
  • Steven May 09, 2013
    I should mention that the display is totally blank. Everything else on the unit works.
Cd player doesn't work
My brother took the case off my JVC system and the ground wire was off. He fixed that and everything works just fine YAAAY!
Aug 11, 2014 | JVC UX-T3 Shelf System
LED display is now blank
Had the same problume I traced it to capactor C25 100uf 16v I also replaced C32 102nf
Dec 13, 2012 | JVC Ux-lp5 Audio Shelf System
How do I connect my jvc ux-vj3 to the tv
I have the same problem, thought it might have been my iPod , but hooked iPhone up to it to and same thing. If someone has a solution I'd like to here
May 19, 2012 | JVC UX-VJ3 Dual Docking Mini Audio System...
My JVC ux-g50 stereo display does not illuminate. Is there a fuse to check or other solution?
Hello
There is no fuse to check, but have to check voltages at the display section. It is a very skilled job, and you must have through knoledge in electroncis and all tools to do this as well as its schematic diagram and the knoledge to follow it. OK.
Jan 14, 2012 | Harman Kardon JVC UXG50 Micro Stereo...
Install a refill UX-B750 cartridge but display still showing out of ink.
The machine is not identifying the cartridge properly. Attempt to reinstall the cartridge. It just may be installed incorrectly.
Dec 09, 2009 | Sharp UX-B750 Inkjet Fax
Sharp UX-117 display Wait a moment on power on and then no signal
I have not worked on a sharp ux-117 before, however most sharp fax machines are all alike when it comes to resetting this code. Turn the fax on while holding down the stop and start key don't let go until you see 1 =yes, 2=no for memory clear. press 1=yes. Some of the sharp fax machines have a small white rounded reset button. No guarantee but you have nothing to lose.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
JVC micro system hi fi model UX-DAB11
One possible problem is the display IC of your JVC is damaged already or it is not connected properly due to mishandling. display IC has small pins and therefore have small connectors, even if you trace those connections you may find it hard to solder it, but if you have the right tools you may proceed. To trace the pins of the display IC if it is connected you must use an Ohmmeter. Here is a simple steps: an ohmmeter has two wires that has a pin on both ends, most tester has colored wires the red and black. You must point in contact either pins on the subject points in the circuit and the other pin on the circuits also it must be in contact. If the ohmmeters display gives a reading of 0, then there is connection, otherwise it will give a number that indicates there is resistance which means there is no connection or poor connection on the subject. Repeat this procedure until you find all possible disconnection. NOTE: Do this only on the part on the dispaly IC and the DISPLAY connections.
But the best thing to do about it is to bring it to the service center.
I hope i've provided some form of help to you.
Feb 11, 2008 | RCA RS2625 CD Shelf System
Sharp ux b700
check carriage home postion sensor(often in your left hand near left end of the machine-check for a broken connector and reconnect it-check for droped object or dirty in the sensor.
Jan 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
50 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
