Question about Manitowoc QY-0134A
Does not work
Does not do anything sounds like it is working but does not make ice
My refrigerator is making ice but the dispenser is not working. I don't hear the motor or anything turning when the dispenser lever is pressed.
Hello Rose:
My name is Peter. I am a retired field service refrigeration technician.
Please send me the model number and I will help you. There are several different drives and solenoid valves
Dec 10, 2014 | Refrigerators
Freezer not staying frozen and ice maker not making ice
Sounds like your fridge guy is right. Just be sure coils are defrosted again when new heater is installed.
Sep 22, 2017 | Electrolux Refrigerators
My whirlpool side by side is not making ice and im wondering if the sound it usually makes, like water filling up, doesnt happen anymore have anything to do with it???
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Nov 01, 2011 | Refrigerators
I have an upright Whirlpool side by side fridge freezer, there is ice build up inside under the ice bin/water dispense, I emptied the ice and turned off the ice maker but it is still there and getting...
It sounds like the auto defrost cycle has stopped working.
Manually defrost the freezer.
If things work better then it is the defrost cycle which is faulty.
A technician can help you with that
Mar 30, 2011 | Whirlpool GAFZ21 Bottom Freezer...
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
No water to ice maker
This just may be the thermostat inside your ice maker causing the problem. The part number is 627985 Thanks, Sea Breeze
Aug 26, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker working fine - Water dispenser nto doing anything
hi there,
sounds like the water valve may be the culprit.
can you provide the model # off your fridge please?
Sep 21, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Manitowoc QY-0134A Logo
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
George Merkley
George Merkley
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
