Question about Pioneer Gm-d8400m 1200w Max, Class D Mono Amp Gmd8400m
Power light flashing
Blue light pulses
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
Posted on May 10, 2013
Lost my dash light on my 1999 grand marquis
Probably a problem with the LCM - lighting control module . The main light switch is a input to the (LCM) . Here is free wiring diagrams http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model an engine size . Under system click on lighting , under subsystem click on insturment panel lamps . Click the search button then the blue link . Do you know how to test PWM ,this is how the LCM controls the lights .
Pulse-width modulation Pulse-width modulation (PWM), or pulse-duration modulation (PDM), is a modulation technique used to encode a message into a pulsing signal. Although this modulation technique can be used to encode information for transmission, its main use is to allow the control of the power supplied to electrical devices, especially to inertial loads such as motors an lighting .
Pulse width modulation
Jun 15, 2017 | Cars & Trucks
Truck shuts off while driving
Check the fuel pressure with a fuel pressure gauge, when the truck stops See if the fuel injectors are getting a pulse with a niod light plugged into the harness "while cranking. motor". IF you get no pulses (NO flashing noid light) see if the security light is ON, on the dash. If the security system "kicks on" it will kill the pulses to the injectors.
Jul 27, 2014 | 1999 Chevrolet Silverado 1500
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I have the SSC-1500A battery charger and the yellow light keeps flashing. The yellow light is the charging light.not sure why
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
Sep 23, 2010 | Schumacher 400w Power Inverter
Amp won't turn on, red light on amp is flashing
DID THIS JUST HAPPEN ALL AT ONCE ? OR DID IT GRADUALLY HAPPEN? CHECK GROUND FROM AMP , INSTALL ONE FARAD CAP . STOCK RADIO ISNT REALLY HELPING , MOST AMPS OF TODAY TAKE A HIGHER SIGNAL FROM HEAD UNIT . ADD ONE FARAD CAP AND SEE
Jan 17, 2010 | Car Audio & Video
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
How to test check engine light on a 1991 honda accord? Computer has no light on it like most honda's
These utilize a jumper connector(scs) in order to retrieve codes. It's location is just a little different for different models of hondas and acuras but generally speaking there relative to one location.On your car if you go to passenger front seat area and find the lower rt hand kick panel(to rt of your foot if sitting in seat)reach your hand just to the top edge of the panel you'll find a small blue 2pin connector.sometimes its got a small piece of tape holding it loosely to a wire cluster ,just pull it free of tape. With ignition key in off position,jump terminals together at connector with jumper wire,paper clip works fine.With jumper installed turn ignition switch into on position,not start just in run position.Observe check engine light.If DTC is stored check engine light will flash in series of pulses which are numbers of DTC. One long pulse is equal to ten, short pulses equal to one,example would be one long pulse pause followed by 2 quick flashes.this would be code 12 (EGR Problem). It will repeat this set of flashes 3 times,with long long pause between each.if multiple dtc are stored each DTC will be shown once,one rt after other,than will repeat series set over again for three series repeats then light will stop flashing.
NOTE:As i was saying about scs location,it is always found on Hondas/Acuras on passenger side seat area.it will be in one of following spots. 1.at back top edge of carpet where it meets up to dash area,to back edge of (ft side)center console piece(by left foot),behind rt kick panel as above or where lower hinge side if glove box meets dash,resting in that seam.always blue or grey 2 pin connector not connected to anything.Good Luck!joel
Nov 11, 2009 | 1991 Honda Accord
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Open Questions:
See all Pioneer Gm-d8400m 1200w Max, Class D Mono Amp Questions
Pioneer Gm-d8400m 1200w Max, Class D Mono Amp Gmd8400m Logo
191 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
