Question about Kitchen Ranges
Flavel cooker model FL92FRXP
Would you know where I may be able to get a black clock trim for Flavel FL92FRXP Single Oven 90cm Dual Fuel Range?
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
  • 7 Answers
SOURCE: Stoves dual fuel cooker
if your qulified enough you need to bypass the timer electrically so as to put power direct to the oven
Posted on Jan 07, 2008
SOURCE: Small Electric cooker on Range does not reach temperature
The orange light is designed to go off when temperature required is achieved in the oven. If the light remains on it suggests that the oven is not heating, It could be a thermostat problem but it's more likely to be the element.
Posted on Jul 07, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
I have a flavel AP10FRSP range cooker the fan oven completely dead no power. is it the element or te fan that needs replacing please.
Fans in the ovens are subjected to extreme heat and this dries the shaft bushings of lubrication, so the fan is not really dead; it is that the fan is struggling to rotate but can't because of sticky and worn out bushings. You should start the oven with the door open and listen for tell tale sign of scraping sounds. If you can reach the fan, rotate it by hand and see if it rotates freely and long, without any signs of scraping noises. If the fan is fine, then the switching electronics may have burned out and need replacement. Flavel is a good brand. Send an email and they will tell you what to do.
Dec 28, 2014 | Kitchen Ranges
Wiring Diagram for a Flavel Range master cooker
I don.t have a manual,that is hard to find,yet a oven is a basic device,most of components can be id and tested by amateur electronic,like switches,fuses,heater resistance,control board.no need to remember Electric Shock Hazard !!
regards
Oct 28, 2014 | Car Audio & Video
Flavel victoriana 50 gas cooker
Standard appliance parts in Sacramento
Jul 02, 2013 | Heating & Cooling
Does anyone know where to order a thermal trip for a Flavel milano 100 cooker. The right hand oven has stopped working and I have been trying to find the spare part to no avail. Cheers
The following address has a list of sites that sell oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 14, 2011 | Toaster Ovens
Instruction manual for a flavel cascade 50 gas cooker
i have a flavel cascade 50 oven i can light it with the pilot light but once i release the knob the oven does not stay alite how do i solve this
Sep 27, 2010 | Ovens
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Flavel 100 finesse problem
I have a Flevel 100 and wish I had checked out all the problems everyone is having first as I would never have bought it...what a waste of money...already replaced the element on it...the ordinary cooker died weeks ago...now the fan one has died leaving me with no means of cooking in an oven...this is going to the nearest dump as soon as I can get to the shop to buy a very cheap standin...Flavel I hope you are ashamed!
Apr 22, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
