Error code e014 - Office Equipment & Supplies
  • 1,326 Answers
I'm going to guess at what kind of copier you have..... Is it a Canon ??? If so, the code means that there is some thing dragging the speed of the main drive motor or the fixing unit. I'm not sure what model of copier you have, so you may have a web that has wrapped it self around the upper fixing roller or a claw has dug into the lower fixing roller or it could be worn or locked up ball bearing in the fixing unit. The code can not be rest till the problem is fixed. I would start turning the fuser & if it will not turn, that is where your problem is... Be carefull if you start touching the fuser... IT GETS VERY, VERY HOT..... Good Luck
Posted on May 08, 2013
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Posted on Nov 07, 2008
Cogz
  • 1326 Answers
SOURCE: how to fix error code E014, it shows on screen
If I remember correctly..... A E014 mean that the main drive is not spining freely. Most of the time the fuser unit is not turning smoothly. Have you tried to spin the fuser unit? If so is it smooh or tight? Have you looked in the fuser to see if the web is wraped around the upper fuser roller? Or is the lower fusing roller cut? If that all looks OK > it is the fuser drive gears (on the front of the fuser) are locked up... You may have to take the two white gears off and clean & lubract / oil the shafts.... Good Luck > there is not a way to reset the code until it is fixed
Posted on Feb 05, 2011
Canon ir400s E014 error code problem
I dont know that model,but on the others it may be waste toner bottle full,or fixing motor faulty
Oct 15, 2014 | Canon Office Equipment & Supplies
How to fix error code E014, it shows on screen switch main power off and on then E014, but I turned off and on many time , it stay like that
Feb 04, 2011 | Canon imageRUNNER 400S Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
No print, e805 and e014
The E 805 refers to a locked up fan motor, and the e014 is for the fuser (the part that get hot) not turning correctly. both of these problems require a technician to fix.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Error e014 on canon gp 605
I THINK E014 IS FUSER UNIT MOTOR.REPLACE MOTOR.DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 22, 2009 | Office Equipment & Supplies
Error Code E014 Casio PCR-T470
Hi. When they run out of paper, you just load a new roll, and the machine will automatically continue. There is no need to clear the error. It will continue when it senses fresh paper in the receipt side.
Jan 11, 2009 | Casio Parts Cash Register PC Desktop
CANON GP405 ERROR E014 PROBLEM
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Iam getting error code E010,E014
Nov 06, 2008 | Canon Office Equipment & Supplies
Error codes
E000 and E001 is due to the laser unit, I can explain in more details.
E014 is due to the Dc motor failing
Hope this helps?
Oct 17, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
18 people viewed this question
jasbo
jasbo
