Question about John Deere Weather Station Rain Gauge Wind Speed
Replacement part i would like to know how i can find out where to order a new glass tube for my rain gauge? Model #LP10163
  • John Deere Master
  • 15,557 Answers
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
How do I get order new window fow my coby 7 tablet it window crack wont open serviceso it need replace window glass.
Go to Google or you tube and enter the information of you device that you intend to fix. I did it when my clr get broken , I get a video step by step. Good luck.
Jan 04, 2015 | Coby kyros Tablets & eReaders
I have a 2009 Kai magentis, I need to replace wind shield, does the wind shield have a censor in it or can I place with ordinary windshield
ask supplier of winshield
The most common modern rain sensors are based on the principle of total internal reflection: an infrared light is beamed at a 45-degree angle into the windshield from the interior - if the glass is wet, less light makes it back to the sensor, and the wipers turn on.
TeleGlass Auto Glass The Easy Way Windshield Rain Sensors
Do Have Rain Sensor Gold Coast Auto Glass
Oct 13, 2014 | Arkon New Cmp114 Camera Video Recorder...
Are there different types of rain gauges?
There are a few different types of rain gauges. Standard rain gauges, Weighing percipitation gauges, tipping bucket rain gauge, optical rain gauge and the aucoustic rain gauge. They each measure rain in a different and some of them interesting ways.
Dec 29, 2013 | Garden
Rain gauge not working on model c86234
Replace the glass reed switch on the circuit board as it is bad. You must be very careful to orient the replacement switch so that it closes only when the rocker arm is at the vertical position. This will take some work to get right. Use a volt ohm meter and set the Plus lead at the reed switch lead at the top of the board. The meter should show a closed circuit only when the rocker is at the top. Good luck.
Jul 15, 2013 | La Crosse Technology La Crosse C86234...
I need to replace one of the gauges (cracked the glass) on my Makita MAC5200 compressor. Is there somewhere I can find the instructions for doing so?
Makita has used several types of gauges over the years and all had removable lens/glass held on by screw or threaded lens. Most simple repair would be to purchase gauge and just swap out glass/lens. Order from www.toolpartsdirect.com. Good luck
Jan 12, 2011 | Makita MAC5200 Electric Powered Air...
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Mar 12, 2009 | Thermador REF30 Electric Kitchen Range
Scratched Glass Television Screen
you will need to replace the tube there is no screen its the actual face of the picture tube. very expensive around 500 for a new tube that size. I have a source for used rebuilt tubes for around 275.00 shipping included. If interested let me know the model number and I will inquire as to the availability.
Mar 24, 2008 | Televison & Video
John Deere Weather Station Rain Gauge Wind Speed Logo
204 people viewed this question
Top John Deere Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a John Deere Measuring Tool and Sensor Expert? Answer questions, earn points and help others
