Question about Vehicle Parts & Accessories
Any suggestions to the problem
I dont know if it could be the starter or if it's the alternator or the spark plugs im open to any suggestions hopefully from someone who has had this problem fixed before
  • Vehicle Part... Master
  • 16,387 Answers
What is the problem?
What is the make, model and year?
Posted on May 09, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My 1997 Altmia keeps stalling and putting when I stop or slow down. I changed the wires and spark plugs but it is still doing it. It cut off several times today. When I had the lights on the inside and...
sounds like your alternator could be going bad, most major autoparts stores will do a free battery, starter and alternator test, and tell you what your problem is. just make sure you ask for a full charging system test otherwise they will probably just check the battery (if the battery tests bad you wont get an accurate test on your alternator, so replace the battery then have them run the test again right away) If it is the alternator, dont let it go too long, a bad alternator can kill your battery, a bad battery can kill your alternator and starter, and a bad starter can kill a battery.
no promises that this is your problem but it is where I would start, there are other possibilites as well, such as a weak feul pump or clogged fuel filter, if your engine isn't getting enough gas it will dog down and stall. But like I said above I would start with the battery/alternator/starter test.
Sep 01, 2012 | 1997 Nissan.5 Altima
My van wont start
Alternator isnt the problem, just for charge. First test charge battery, will need 12v to start.
Additionally, I suggest check starter and starter solenoid (if you have one there), ignition switch and aftermarl or antitheft system.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | 1998 Plymouth Voyager
Chevrolet want turn over
Hello and welcome to FixYa!
As a first course of action I strongly suggest that you charge the battery. If the battery is weak, there will be no enough current to the starter to kick the flywheel. One good reason why the vehicle won't turn over.
If the battery is fully charged and still won't turn, then I strongly suggest that you replace the starter itself for it can be the one faulty.
Hope this helps and thank you for using Fixya! Have a good one!
Apr 28, 2011 | 1997 Chevrolet K1500
Im having problem locating the suggested spark plug ngk cr7e, can you suggest alternative brand or specification of spark plugs?
Most auto stores can order in the spark plug you are looking for.
NGK CR7E BOSCH XR4DC DENSO X27EPR-U9
Sep 09, 2010 | 2000 kawasaki VN 800 Vulcan Classic
1998 dodge ram will turn over but wont start.
just replace your alternator and you will be fine also you might check any wires hanging around just to make sure nothing touching the body ok goodluck
Aug 12, 2009 | 1999 Dodge Ram
Electrical problem...
hey
before i start....it is def not the alternator. the only job a alternator has it a car is to charge the battery when the engine is started it generates power for lights etc!!! by not starting does the engin turn atal? if the engin does not turn i would check the starter motor!! if the engine is turning i would check to see if there is a spark!! take a plug lead of and put a spark plug into it and turn the engine!! if there is no spark..then the distributor is gone!! if there is a spark them check your fuel pump!! disconnect fuel pipe and turn engine and if no fuel comes out it gone either!
hope iv helped you
Damien
Aug 20, 2008 | 1994 Honda Civic
I have an 86 t bird
Have you had the alternator checked? I had a tbird doing something similar and it turned out the alternator went bad on me.
Jul 08, 2008 | 1989 Ford Thunderbird
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
