Question about Cycling
Echo F7 I/ve just changed the battery of my echo f7 cyclocomputer and wiped out the setting for the wheel size. What setting correspods to wheel sizes - 26'' wheel?
  • 4 Answers
SOURCE: Wheel size
2105mm should get you very close.
Posted on Sep 20, 2009
  • 13 Answers
SOURCE: I have a Huffy 13F WIRELESS COMPUTER for my bike,
go here:
http://www.huffybikes.com.au/index.php?module=product-detail&product=11
and contact Huffy. They can email you another manual
Posted on Oct 03, 2009
SOURCE: Have lost Echo W1 instructions. Can I get
Y've got the manual; send me an email to fortez@tin.it , so I can reply with a pdf enclosed
Posted on Dec 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: The wheel size chart in the instruction manual
It's in the manual. Measure the wheel size and enter it manually.
http://www.sigmasport.com/en/allgemein/showdatei/?download=1&name=2_1_Manual_BC_1106_nat.pdf
There's a picture of how to determine the circumference by rolling the wheel one revolution and measuring it. Be as accurate as you can (to the mm).
4. Wheel size BIKE 1
• Press MODE to change to BIKE 1.
• Press SET briefly and the first digit flashes.
• Set the value by pressing RESET, change to the next digit by pressing MODE.
• Bike 1 is always the bike with the handlebar holder WS 1
Posted on Feb 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: I'm trying to set up the correct wheel size for my
The manual explains how to measure your wheel exactly and set it into the computer...
http://www.sigmasport.com/en/service_center/produkt_support/bikecomputer/?flash=1&typ=bikecomputer
Page 28 and 30.
Posted on Feb 08, 2011
What dose the code f7 mean on a Battery charger.
F7 Long charge, the charger ran longer than 6 hours from the gassing voltage. - Open diode - Low Charging amps - Low AC line voltage - Wrong size battery - Battery over-discharged
press the helpful button
http://giantbatteryco.com/gbweb/ChargerDiagrams/FerroTransTaps.pdf
Jan 30, 2016 | Ovens
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
I just bought a Bell Wireless Cyclocomputer (15 function) and I can't figure out how to set the tire size. Ive been holding down both buttons for different amounts of time and and I can't get it...
after holding down both buttons for 3 seconds those four numbers show up . They are changed according to the tire measurement. Use the chart in the manual to determine your four numbers. then set each digit by repeatedly pushing the set button. push the mode button to advance to the next digit. After the fourth digit is set the set mode will advance to the next setting.
Jun 10, 2011 | Cycling
I HAVE TWICE POSTED MY PROBLEM ALRAEDY IN THE LAST COUPLE OF HOURS,. i HAVE A N ECHO Wireless Computer W1 - in changing this between bikes I have somehow manges to lose the setting up instructions, I am...
Go back to where you bought it and see if they have an extra set of directions. If, they don't maybe they can call the manufacturer of Echo. Or you neighborhood bike shop mechanic may know the numbers for your wheel size.
Aug 22, 2010 | Cycling
How do I calculate wheel size for my bike. 25 inch wheel without tire for example
There's a size chart on page 15 of the manual that has great instructions for measuring and entering the wheel size.
You can get the manual from Sigma's website at this link.
Method "B" is the most accurate way -- make a chalk mark on the tire and stand the bike up next to a wall with the chalk mark at the bottom.
Have a friend make a chalk mark on the ground at that point.
WITH YOUR FULL WEIGHT ON THE BIKE, move forward for one rotation of the wheel -- until the chalk mark is on the bottom again. Do this as straight-line as you can.
Have your friend make another mark on the ground at this point, and measure the line between the two points on the ground.
This is the wheel circumference, and if you do this with normal tire inflation and with your full weight on the bike, it's the most accurate way to calibrate your cyclocomputer.
If this helps, please be sure to hit the "thumbs up" for me.
If not, of if you have questions, use "add comment" to post back here, and I'll do my best to get you going.
May 20, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Time to replace tires need suggestions to improve ride.
call the tirerack, they are the industry leaders for info like this.
phone 888-541-1777
Mar 13, 2009 | 2002 Toyota ECHO
Cycling Logo
127 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
