Question about Kenwood -TK2100-2140-2160-2200-3100-3130-3131-3140-3160-3200-260-270-272-360-370-372-373 Comp... 2-Way Radio
Kenwood R 600
The problem is the vfo frequency display is stuck at 99.545. The band switch works, the vfo does not change frequency though it does you can not see it on the display is there a reset or whatever i can do? Thanks.
  • salaar
    salaar Dec 28, 2013
    Hi Gary Ohlson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
4 Suggested Answers
Barry Mung
  • 7 Answers
SOURCE: kenwood R-600 amateur radio receiver tuning problem
If its like the older yeasu's, they had a black and white veined disc on the back with opto electronics, dust used to get in and obscure the sensors...
Worth a look.
Posted on Dec 29, 2007
BillB-SA
  • 2761 Answers
SOURCE: Hello,I have four walkie talkie
Elio:
Your local Kenwood rep is correct for a couple of reasons:
1. The cost to modify your current radios to operate on the Italian band would be higher than the price of new radios.
2. Operating modified radios would be a violation of Italian laws.
Bill B
Posted on Nov 05, 2010
ginko
  • 19396 Answers
SOURCE: My TH79A keypad does not
Hi.
It looks like the key panel is defective and must be replaced. Standing to your description the receiver is working. Here the biggest third party part seller. Call them and find out if the panel listed in parts includes the key pad.
Kenwood has no parts for old model. If Partstore does not have the spare, try Kenwood, or look for second hand parts on Ebay.
Regards.
Ginko.
Posted on Mar 31, 2011
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
Vfo changes frequency but will not let you tune fast. Even with step switch on won't let you go fast.
FLDIGI Users Manual: Operating Controls and Displays
www.w1hkj.com/FldigiHelp-3.21/html/operating_controls_page.html
Let the mouse cursor hover over any one of the controls and a small hint box will open to ... This will be very fast and should not require additional operator intervention. ... In the display above you can see that the audio signal is 1500 Hz. The red cursor is ... The TX continues to be locked, but at the new audio frequency.
Baofeng UV-82 Switching Between Memory and ... - YouTube
? 2:18
https://www.youtube.com/watch?v=PqfcbfiZIGs
Mar 7, 2014 - Uploaded by Benjamin Gaston
... left off the V/M button that allows you to change between Memory/Channel mode and the VFO where ...
The ARRL Operating Manual for Radio Amateurs
Nov 26, 2015 | Cars & Trucks
My kenwood ts 700sp display stopped working. It don't change when I rotate the dial. Was working fine now it just stays on 144.000 Where should I look?
I had this happen on a Kenwood and this may be what has happened to you. Take your top and bottom covers off and then you will need to undo the front panel from the chassis so you can tilt it to be able to get to the main dial VFO encoder. You will need to remove the main tuning knob and then remove the encoder and take it apart. What happened in mine was the main encoding wheel which is a very thin round wheel with tons of small slots that break a light beam causing the frequency to change. My encoding wheel glue let the disk come off. The shaft turned but not the encoding wheel itself. Check this first. If you have a scope you could check to output pulse train of the encoder before taking it apart. No pulse train from the encoder could mean the disk encoder wheel is not moving. Good luck. Dennis
Aug 10, 2015 | Kenwood Radio Communications
How do i turn off the tnc indicator on the ts2000
per the manual the main band is the default for the built in terminal node controller you may have to change it manually by pressing the vfo A or B.
Oct 24, 2014 | Kenwood TS-2000
Hello,I have four walkie talkie brand new from Kenwood, UBZ LF 14, and they work in the PMR band. Now I'm living in Italy and the PMR band is not allowed for family use by the Government The family...
Elio:
Bill B
Nov 05, 2010 | Kenwood ProTalk UBZ-AM14 (14 Channels)...
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Jan 31, 2009 | Icom IC-R5 Handheld Scanner
Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Dec 22, 2008 | Icom IC-R5 Handheld Scanner
Problem with a Kenwood TS 2000 Amateur Radio Transceiver
73s I have heard of similar problems and some were heating related. the best is to check if your rig is heating up causing it to switch off and lose memory when switched back on. I have a buddy who had an unusual experience where he actually dropped frequencies so low that he could pick up ordinary radio frequency and also go into bands like 27mhz and 25mhz. But once switched off, the rig worked normal again. If you are experiencing heat problems then i suggest you put in a fan and remove all dust from inside the rig. You could probably also be having problems with power supply either internal or external. If all else fails, refer to a good repair shop this type of radios are very sensitive.
Oct 01, 2008 | Computers & Internet
Icom r5
A quick "get you started" guide.....
to do this....
To set the step....
To scan...
Thats it!
M3ODQ
Jun 24, 2008 | Icom IC-R5 Handheld Scanner
Kenwood R-600 amateur radio receiver tuning problem
Worth a look.
Dec 26, 2007 | Kenwood...
Radio Communications Logo
62 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
