Question about ASUS Computers & Internet
Asus a52f laptop won't power turn on after replacing the mother board
  • ASUS Master
  • 32,281 Answers
The RAM or the CPU maybe faulty.
Posted on May 08, 2013
jilpeshpatel
  • 259 Answers
SOURCE: Laptop Drivers for L8400
http://support.asus.com/download/download.aspx?SLanguage=en-us
click this link and downlod the driver.........ok
Posted on Mar 30, 2009
LaptopExpert
  • 458 Answers
SOURCE: HP Compaq NX9420 Laptop Power supply shorted ou
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Posted on Dec 01, 2009
  • 355 Answers
SOURCE: My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Posted on Feb 08, 2012
  • 285 Answers
SOURCE: my asus a52f not turn on after bios update
never change ur bios setting/pdate without the clarification of ur laptop service provider. its better to go to ur laptop service provider before other damages are done.i guess you might have crash ur operating system
Posted on Mar 09, 2012
SOURCE: Dell 1749 won't boot power light flashes 3 times
You've got an issue with your Memory or the Video Card.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Posted on May 16, 2012
Asus a52f usb not working
check the drivers are in
Apr 21, 2014 | ASUS A52F-XE2 Notebook
My asus A52F sound is too low
Right click on your speaker icon, click on volume mixer, check the slider, should be right up, also check recording and playback, if not working, you can troubleshoot sound problems, you can try this out.
Feb 07, 2013 | ASUS A52F-XE2 Notebook
MY ASUS F5VL MOTHERBOARD WON'T TURN ON???
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
AC adapter failure.
Power jack failure.
Motherboard failure.
Possible troubleshooting steps and repair solutions:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Oct 30, 2012 | ASUS F5VL-A2 Notebook
Few keya are not working
To determine if the keyboard or the keyboard controller is faulty, plug an USB keyboard into the USB port on your laptop. If all the keys are OK on the USB keyboard then the laptop's keyboard is faulty and needs to be replaced. If the USB keyboard also malfunctions then the keyboard controller chip on the motherboard is faulty, then the motherboard needs to be replaced, but this may not be a cost effective solution.
A replacement keyboard for your model laptop maybe available from this WEB site.Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 07, 2012 | ASUS A52f-xe6 A52f Ci5/2.66 15.6 4gb 500gb...
Is changing the battery in this notebook as simple as merely sliding in the replacement battery?r
You are correct
1) Simply shut down your laptop
2) Disconnect it from power
3) Remove the Old Batter
4) Slid in the New Battery
5) Connect power
6) Now you should be ready to go but its always best to give any batter a bit of a charge before you use it
7)Then Switch it on and your good to go
Hope that Helped
Jaysan
Jun 16, 2012 | ASUS A52F-XE2 Notebook
A52F keyboard problems
Looks like your keyboard has been hijacked. Turn your computer off and boot up in Safe Mode. When you hit the power button to turn the computer on immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. Once safe mode is up things will look different to you. The icons will be bigger and the screen will be darker, that's normal.
If this started happening to you recently say only a day or two ago then lets try doing a System Restore to a date and time before it started happening. Click Start/Programs/Accessories/System Tools/System Restore. When System Restore pops up look for an option that will allow you to pick additional restore points than the one you see. You want to pick a date and time that was before your keyboard started acting crazy.
Let it run to completion then try typing again.
Don't worry, System Restore does not destroy your data, documents, music, pictures, videos, (programs (unless you added a program after the restore point you selected)). System Recovery destroys everything and sets your system back to when you first purchased it.
Mar 22, 2012 | ASUS A52F-X3 PC Notebook
I press f8 when starting but unable to get into safe mode. I have windows 7 OS on an ASUS A52F.
You have to tap F8 Repeatedly right after the initial splash screen goes away. Then it will come up with a menu for you to choose Safe Mode.
Jun 30, 2011 | ASUS A52F-XT1R 15.6" Laptop Computer PC...
Wi-fi stoped working,just has an x on it cha
Several things could be at issue, but we start with the obvious. The very first is to make certain that the (generally) mechanical switch that controls your wi-fi on the laptop is turned on, typically indicated by a light near the switch or elsewhere. This is the usual cause of WiFi malfunctions. Another is a driver problem, in which you could just uninstall your driver and have Windows restore it for you. But as a warning, if you do that, it's best to have a CAT-5 cable for direct connection to a router handy in case your driver won't reinstall. The last thing is that the wireless network adapter has malfunctioned. It's unlikely, but you can either replace the one built-in or purchase an external (very cheap at placed like NewEgg, Tiger Direct, or Meritline).
May 20, 2011 | ASUS A52F-XT1 Notebook
When I type on my ASUS U50A notebook, the cursor jumps ahead and behind, especially when I'm tying the letter "o". How do I fix it?
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
We are committed to supply a variety of laptop parts for fulfilling your needs.
<a href="Asus'>http://www.laptopparttips.info/2012/09/09/asus-n53sv-keyboard/">Asus N53SV Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-n53sv-keyboard-replace.html">Asus N53SV Laptop Keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus G60jx White Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-keyboard-replacement.html">asus g60jx black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g60jx-cpu-fan-replacement.html">asus g60jx laptop fan</a>,
<a href="replace'>http://www.laptopparttips.info/2012/09/09/how-to-replace-fan/">replace cpu cooling fan</a>,
<a href="Asus'>http://www.laptopparteshop.com/asus-g53-white-keyboard-replace.html">Asus g53 keyboard</a>,
<a href="Asus'>http://www.laptopparteshop.com/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&q=asus+a52f&cid=0">Asus A52f laptop Part</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-lcd-cable-replacement.html">asus a52f lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-keyboard-replace.html">asus a52f keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-battery-replacement.html">asus a52f battery</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-a52f-cpu-fan-replcement.html">asus a52f laptop fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-a52-white-keyboard-replace.html">asus a52 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-keyboard-replace.html">asus k53 keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53-lcd-hinges-replacement.html">asus k53 lcd hinges</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-cpu-fan-replacement.html">asus k53s cpu fan</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-k53s-lcd-cable-replacment.html">asus k53s lcd cable</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50-keyboard-replace.html">asus u50f Keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73jw-g73s-keyboard-replace.html">asus g73 black keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">asus g73 white keyboard</a>,
<a href="asus'>http://www.laptopparteshop.com/asus-u50f-u50a-keyboard-replace.html">asus u50a keyboard</a>
Mar 24, 2010 | ASUS Computers & Internet
Which notebook to buy?
I'd ask your professors which one they recommend and if they don't have a recommendation ask them what they use or better yet what they would like to use if they could afford it!
good colleges should recommend a compatible laptop that will easily sync with their school system!
Feb 09, 2009 | Sony Computers & Internet
Computers & Internet Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
