I have a Technika TV LCD 40-270 and i have just bought a LG sound bar how can i get this sound bar to work with my Technika TV as the soundbar is optical digital and my TV is not any advice please
I have a Technika sound bar and no remote, so I have a one4all remote but cannot find code for soundbar it is not on the database It is a TKSB215/70 Any help would be appreciated
I just acquired an Xfinity (Comcast) remote that has codes for soundbars (but not Technika) so your odds of success depend upon choosing a suitable universal remote.
Jan 06, 2017 | Televison & Video
Bought a lg soundbar and optical cable connected to back of tv with jack adaptor but soundbar won't work can someone tell me if why? Thanks
I am going to guess here that you are running this through an audio system or a cable box. Your audio needs to come form the source, not the TV. Ex. If you were to go optic cable out of your cable box and into the TV optic then you would get sound out of your TV speakers. Go direct to sound bar.
Nov 29, 2015 | LG Televison & Video
How do i connect a technika TKSBSE213 soundbar to a telly
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
Jan 18, 2015 | Audio Players & Recorders
How do i connect my soundbar to my technika lcd 32-244 tv
There should be a output on the TV. Hook the sound bar up, set the TV up to use external sound and use the sound bar remote untill you sync it to a different remote. Give it a try!!!!
May 22, 2014 | Televison & Video
Optical out not working with LG sound bar
got same problem the LG sound plate works with bluetoth mode but don't not detect the pioneer tv set..
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
Lg soundbar nb2020a setup
If you are currently using your sound system shown for your television sound then you need to use that with you sound bar plugged into it. You can hook it directly to your TV if you have an audio out but your tv has to produce enough output to run the sound bar. If your tv does have an audio out then there is a good chance you need to make those jacks active in the sound set up menu for external speakers. Some sound bars are powered and will require being plugged in as well.
Apr 27, 2013 | Audio Players & Recorders
Is a lg sound bar system compatable with a lg 42ls3450 tv.
Having the same problem. Can't connect the soundbar via HDMI as the LG 42LS3450 does not support Audio Return Channel over HDMI. Which means I'm only left with optical cable, but the TV doesn't seem to have that either!
Dec 27, 2012 | LG Televison & Video
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
