Question about Toshiba TLP-S10 Multimedia Projector
Driver toshiba tlp s10 - Toshiba TLP-S10 Multimedia Projector
My TLP-S10 lamp will not stay on after a couple of moments.
Is the fan working. Check fan. Very likely the device overheated. If fan is working the air filter might need to be cleaned. See you manual how to clean filter and reset the filter cleaning counter so that the device can work properly again.
Feb 17, 2011 | Toshiba TLP-S10 Multimedia Projector
What is wrong with my tlp s10 it gives the entire picture a blue tint the lamp has done 2700 do I need a new bulb
Check the Video cable that feeds the projector, could be a broken cable or a pin bent -worst case the connector on the projector has broken.
Try the VGA cable on your computer screen.
The lamp does not need replaceing, the lamp emmits white light only.
Aug 06, 2010 | Toshiba TLP-S10 Multimedia Projector
Need a tdp t90a lamp driver module board where can i get one and price - in australia
I am having the same issue, Were you able to aquire a lamp driver module for your projector?
Dec 11, 2009 | Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7...
My TLP-S10 can't operate more than 20 second. it automaticaly turn off and its repeatedly. what is the solution..??
the power supply is bad and needs replacing. the capacitors dry out after a while on toshibas.
Jul 09, 2009 | Toshiba TLP S30 Multimedia Projector
Video Projector from Toshiba
I think it might be the video player or it might be the computer settings and the projecter settings.
Jan 06, 2009 | Toshiba TLP-S10 Multimedia Projector
No video picture
It might be the projecter settings or the setings for you viedio player. One other thing is that itt could be the computer setting you have.
Jan 04, 2009 | Toshiba TLP-S10 Multimedia Projector
FAN ERROR
Hi'
Look like led or white plastic.
Viren
Aug 26, 2008 | Toshiba TLP-S10 Multimedia Projector
TLP-S10 FAN ERROR
I'm not familiar with your specific model, but I do work on projectors all the time (some as large as 35000 lumens). DO NOT touch the lens area. Any movement of those panels will require a reconvergence procedure which is neither easy nor cheap. Use canned air to clean the area of dust. That is about all you can do.
Keep me posted.
Dan
FAN ERROR BUT THE FANS WORK
There are air flow sensors in the unit as well which you may have blocked up when you blew out the fans. If those sensors do not detect air flow, the assumption is that there is a fan error. Try removing the fan and cleaning the entire air flow path.
Dan
Toshiba TLP S10 Projector
http://www.toshiba.de/projektoren/resources/pdf/manual_s10e.pdf That link will take you to the owner's manual. It should answer whatever questions you have.
Aug 28, 2007 | Hitachi CP-X270 Multimedia Projector
Toshiba TLP-S10 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
