FLO Code jacuzzi j 385
Getting FLO code, and No Heat! All the jets work at both speeds, drained, refilled, cleaned filters and pushed water into filter port to no avail. Can hear a pump run when I turn on at breaker for a few seconds, then it stops. Will heat if tub is left off for an extended amount of time, but then will set FLO again.
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
Refilled my hottub and now there is a ''FLO'' signal and the heater will not come on. Pumps and jets work fine.
simple fix its one of two things you did not prime the spa when filling it meaning that u just did not lay a hose in the spa then fill it you always need to prime the heater first along with the circ pump if you do not you will get a thing call airlock which is what it sounds like air in the main circulation pump for the heater.Also could be that u removed the filter while you still had the spa running an clogged the circ pump or it could be the flowswitch. Sounds like u might have a sundance spa an if the flo is flashing its either the air lock or your pump went or its clogged if the flo sign is not flashing then its the flowswitch but in that case w/a solid flo nothing would b working. To fix the airlock just shut the power down an take your hose an force water into the intake side of the filter area this is what u should always do 1st when you fill it that how you prime yuor pump an when fillin it all the way it best to fill it through the other end of the filter just put the hose into the filter tube w/the screw on it.IF THATS NOT IT THEN FEEL YOUR CIRC PUMP IT WILL BE THE SMALLEST PUMP IN THE SPA IF U CAN NOT TOUCH IT FOR MORE THEN A FEW SECS. THEN IT WENT ON U OR IT CLOGGED
Jan 29, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
After I drained and cleaned my "Jacuzzi 220" I filled it and got a FL2 code and now only half my jets work. Is it as simple to fix as disconnecting the pressure switch and reattaching? Thanks, Richard
You probably need to run water into the skimmer to force air out of the suction line. sounds like one of the pumps is not priming due to air lock. When you drain the spa, get into the habit of running water into the skimmer when you start refilling it.
You can get it to prime by loosening the discharge side pump union until the air is out, then re-tighten. The FL2 code is a "flow" error for the circ pump.
Oct 25, 2009 | Pool & Spa
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Feb 15, 2009 | Jacuzzi Pool & Spa
Smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Dec 19, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Indoor jacuzzi bathtub problem
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Nov 27, 2008 | Home
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
