How do you open a nuvi 660
The ribbon cables are clameped in place. The look like they would slide out from the connector if you pulled then hard enough,... you do NOT want to do that. The black portion of the connector is actually a hinged clamp. With the unit lying on a table, face up as it you were using it; lift the top screen half away for the bottom half and tilt it toward yourself. You should see the ribbon cable and the red & blk wires. For the wide center connector and the one on the right, the black piece hinges up an away from you (towards the top). Try the one on the right first. When you flip it up, the ribbon will pretty much fall out. Pry the wide center one on the ends, NOT in the center. The narrow one on the left tilts donw towrds you. For the antenna, the hinged peice is brown, and it flips up towards the right. This one does not just fall out. It needs some gentle wiggeling. Also, I was able to use a T6 torx, T5 seemed a little loose,... yo don't want to strip any screws or you'll be screwed. SpaceVector
