Question about Master Lock 1500iD Speed Dial Combination Lock, Assorted Colors
1500id how do I find the product code of my Master lock 1500iD. The site says that comes in user manual, but in my only instruction came a paper without some code ...
Where do i store my combination
I am not aware of a "Lock Box" or "storage" capability on FixYa.
If you want storage capability for free...
Google free online storage.
  1. Googledrive.com
  2. box.com
  3. dropbox.com
  4. iCloud.com
  5. evernote.com
  6. bitcasa.com
These are just a few available that are very good.
Nov 14, 2014 | Master 1500ID Combination Padlock
I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
Aug 18, 2014 | Master 1500ID Combination Padlock
My master 1500id lock won't move the circle seems very stiff and it won't open. I need to get my stuff for class
Try lock lubricant. Spray it sown around the shackle on both sides, and around the dial. Push the shackle into the lock body to unload the mechanism, then try to turn the dial again - if your hasp has the shackle under tension, it may drag the mechanism and keep it from unlatching.
May 12, 2014 | Cars & Trucks
I followed the directions to set my new lock and it did not work. So I am locked out of my new master lock speed dial 1500iD.
It happened to so many people. As people use to try it on their own and the problem occurs. I think you did not read or follow the manual guide carefully. But now you must call the locksmith guy to fix it. If you live in San Francisco then you can call Locksmith in San Francisco, as they are professionals and can help you out better.
Oct 25, 2013 | Locks & Locksmithing
Reset combination of this 1500iD.
Here is the page:
http://www.masterlock.com/pdfs/5400D_Instructions_Sheet.pdf
Sep 11, 2011 | Master Lock 5400d: Portable Select Access...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
Master Lock 1500iD Speed Dial Combination Lock, Assorted Colors Logo
23 people viewed this question
Top Master Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
