Tgm Inverter air conditioner - Heating & Cooling
Tgm Inverter air conditioner E5 problem don't know what that means and it doesn't do anything. Please help!
  • Anonymous Mar 17, 2014
    MY TGM INVERTER AIR NOT ON AND SAY E1
  • 783 Answers
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Posted on May 07, 2013
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Posted on Jun 26, 2010
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
2rns4u
  • 22 Answers
SOURCE: Portable Air conditioner is not starting and then stopping.
Empty the water out of the collection pan? This will shut the unit down to keep it from ruining your floors. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
My kolin 2.0 hp inverter series what does mean by E5 displayd code
Hi i am aircon tech, the problem of e5 is fan capacitor & relay connected the fan motor.
Jan 19, 2015 | Inverter Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Turns off showing E5
Unfortunately, unless you still have the Owner's Manual for you unit, you may never know what the E5 error code indicates. Windchaser went out of business about 4 or 5 months ago. And with them went any and all information about their AC units and other products they manufactured & sold. In addition, unless, it's an interchangeable part, there are no Windchaser OEM parts available at this time.
Amazingly, there are some retailers that still have the units for sale, but are not telling the customer that the company is out of business. I guess they just don't want to get stuck with the discontinued units.
I wish I had better news & information for you. But, it is what it is.
Aug 24, 2011 | Windchaser PACR10 Portable Air Conditioner
My air conditioner thermostat is showing a capital A. When I press the mode button it gives me options like 01, 02, Fn, r, D... What do I do? I have read the manual, but it doesn't help me at all
It would help me to know what brand & model number AC unit you have. Different manufacturers and models have codes that don't mean the same thing on each brand.
Please advise ... Thanks
Jul 14, 2011 | Heating & Cooling
Hi, I want to know the meaning of the error code of an air conditioner panasonic s91 inverter.Grazie
Grazie, your question is rather confusing, because you listed to different model numbers for to different types of appliances. The "panasonic s91 inverter" is a cooking appliance. Whereas, the CW-X-C243HU is an air conditioner. So, which appliance are you inquiring about? And you didn't even say what the Error Code is.
Perhaps you can be bit more specific.
Jul 13, 2011 | Panasonic CW-XC243HU Air Conditioner
My 1998 Ford anger xlt has a fuse problem...Air conditioner doesn't work and cigerette lighter doesn't work. Are they on the same circuit? I don't have an owners manual. Thanks
Not sure what you mean when you say an air conditioner problem like if the compressor clutch isn't engaging or the blower motor isn't working, that kind of thing. Anyhow, I am about 99 percent sure they are not in any case. What I did do for you is give you pictures of the fuse layouts as well as the descriptions for each fuse (see below). You mentioned that you didn't have an owners manual. If you would like a copy, email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy. Don't worry, there is no cost for it. I hope this helps and good luck.
Jun 21, 2011 | Ford Ranger Cars & Trucks
Heating & Cooling Logo
3,455 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
