Question about Logitech X-530 Computer Speakers
LOGITECH X530 HOW CAN I HOOK THESE SPEAKER UP ON HOME AUDIO OR LCD TV?
  • 58 Answers
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Posted on Aug 11, 2007
SOURCE:
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
My Logitech X530..only the front -left speaker works. Thank you.
Sounds like you have not plugged it in correctly! Have you connected the 3 mini plugs from the speakers into the adapter and then the 2 phono leads into the other end of the adapter and then the 3.5mm headphone jack into your device?
Oct 25, 2014 | Logitech X-530 70-Watt 5.1 Surround Sound...
My logitech x530 speakers are not playing
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 28, 2011 | Logitech X530 5 Speakers
How do I connect a Logitech X530 speaker system to my Panasonic Blue Ray DVD?
The X-530's only audio inputs are the three analog miniplugs required to connect the speakers to a 5.1-channel PC sound card. Unlike some models, the X-530 doesn't have digital inputs or a jack for connecting a music source such as an iPod.
Dec 08, 2010 | Logitech X-540 Computer Speakers
Logitech X530 does not power all 5 speakers
put the gasoline in the logitech ang fire it..
May 08, 2009 | Logitech X-530 Computer Speakers
Logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
Oct 05, 2008 | Logitech X-530 Computer Speakers
Dont know how to set my logitech x-530 speaker system up
http://www.devhardware.com/c/a/PC-Speakers/Logitech-X530-Speaker-System-Review/2/
Jun 19, 2008 | Audio Players & Recorders
Manual
Here is the installation page, http://www.devhardware.com/c/a/PC-Speakers/Logitech-X530-Speaker-System-Review/2/ it isn't the offical one but I think you will find it usefull all the same!
Good Luck,
Chris
Feb 24, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
589 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
