Question about Max-Fridge Refrigerators
Frigidaire fridge electric digaram - Max-Fridge Refrigerators
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
Water dispenser on Frigidaire FRS6R5E refrigerator is not working but ice maker is working fine.when i open the filter area & press the water dispenser button water comes out from that area & when i put in...
At the back cover of the fridge you will find a double electric valve. The easy way to find valve is to follow water supply tube to your fridge
Unplug fridge and check with multimeter if one of the coils burned out and should be replaced. Make sure you close water shut off valve before removing solenoid. Good luck
Nov 14, 2013 | Frigidaire FRS6R5E Stainless Steel Side by...
Frigidaire refrigerator flashing
Check if the bulb holder is not loose.
Jul 29, 2013 | Refrigerators
I need a controls manual for a frigidaire LEEB30T9FEA. I have the Owners Manual and the Installation Guide but neither has how to use the controls of the oven.
Hello - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Mar 09, 2013 | Frigidaire 27 in. Electric Double...
1996 Frigidaire Fridge/Freezer.... The fridge is leaking underneath suddenly, soaking a full sized towel every 2 hours. The water rung out of the towels is slightly brownish in color. No leaks can be...
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
I've got a Frigidaire that always has water on the floor of the fridge.
First of all make sure the condensate drain hose (or pipe) isn't pugged.
If you look in the area of the compressor you will see it. If you dare , blow in it. Please un plug your electricity cord first.
Fuji
Aug 06, 2009 | Frigidaire FRT21P5A Top Freezer...
Frigidaire Gallery stove top spark module is firing once every 30 seconds when turned off.
ok - this is a question regarding a stove - not a fridge - as indicated.
:D
If the ignitors on a gas stove top continuously spark and only stop when the electricity is turned off the problem may be a stuck relay.
Turn off the electricity (unplug) for a long period of time perhaps overnight. Sometimes the relay will automatically reset.
Aug 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Jun 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator (Whirlpool) increase in electricity usage
very doubtfull fridge fault would double elec consumption. look at rating plate and see how many watts then equate this to light bulbs. average light bulb is 60-100 watts (uk). does circuit breaker you turned off only control the fridge?
Mar 21, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
Top Max-Fridge Refrigerators Experts
Dan Stewart
Dan Stewart
Level 1 Expert
mike simpson
Tom Chichester
Are you a Max-Fridge Refrigerator Expert? Answer questions, earn points and help others
