Question about Craftsman Sears Radial Arm Saw 10" Blade Guard,gold,113.29003,113.29002,& Others
Overload protector The overload protector failed and there is no available replacement that I'm aware of. Can I operate the saw by shorting out the protector?
    Sergeant:
  • 468 Answers
Try checking on sears . Consult your manual as well.
Posted on May 08, 2013
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
My ryobi BTS10 won't start.
The Ryobi does have an overload protector (PN 452110003) inside the switch box. It should be resettable from a small hole to the right of the switch on the front of the cabinet. If not, you may have to go into the switch box to check it out/reset it. If the overload protector is OK, I'd check the condition of brushes and brush springs next.
Jan 21, 2013 | Saws
My ryobi bst10 table saw stopped working. The switch appears fine. I am wondering if the overload protector could be a problem. The little button seems loose?
I'm having the same problem only mine is bran new and has only been turned in one time when I put it together it worked then now the switch is lose and does not make a clicking sound what is wrong with mine
Aug 22, 2012 | Ryobi Saws
My Sony DA 5300 Receiver shuts down and displays a protector sign. The strange things is it is not running hot because it happens 5 minutes after I turn it on
It could still be an internal component that fails when it warms up.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 18, 2011 | Sony STR-DA5300ES 7.1 Channels Receiver
The protector light comes on and shuts off audio, even at low volumes. I am wondering what causes the protector light to come on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Jul 31, 2011 | Audio Players & Recorders
DEAR SIR I have a Sony digital processing amplifier TA-AV790DG. its problem with the working no any function working and no sound. display only blink Protector.. what is the...
Generally speaking, an amp attempts to PROTECT itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Jul 12, 2011 | Sony STR-DB870 Receiver
It display 'PUSH POWER/PROTECTOR
Jul 12, 2011 | Sony DAV-DZ720 Theater System
When open, it show message (push power protector)
Jul 06, 2011 | Audio Players & Recorders
Push power protector
Jul 05, 2011 | Sony DAV-HDX500 System
Craftsman Sears Radial Arm Saw 10" Blade Guard,gold,113.29003,113.29002,& Others Logo
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
