Question about Coffee Makers & Espresso Machines
Cuisinart coffee pot
My coffee pot stopped working
  • 783 Answers
His EXACT situation happened to me 2 days ago because it gets clogged. Flush and dump clear HOT water threw the tank several times. When I did this, clumps of coffee came out and the coffee maker worked great again. In hindsight..it was my bad because the manufacturers say to run a clear vinegar flush threw them once every 6 months, followed by 2-3 clear water flushes to remove these "clots" that plug it up. Hope this info is not too late and you didn\'t throw your machine out. :)
Posted on May 07, 2013
SOURCE: Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Posted on Jul 16, 2008
  • 12 Answers
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Posted on Dec 27, 2008
SOURCE: I Have a Cuisinart Automatic
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
Posted on May 31, 2009
  • 85 Answers
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
freetek
  • 5568 Answers
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Posted on Jul 15, 2009
If this is not an electrical problem, try the following:
Try running a cup of WHITE vinegar (of course without the coffee), this will clear out anything on the path.
Once you do this, run 5 cups of plain water (again without coffee) twice to clear out any vinegar flavor from the path.
Feb 01, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I cannot brew one pot after another. It seems that the heating element will not cool off so it will not trigger the fresh pot to brew.
Do you turn off the pot before you refill the reservoir to brew the second pot? The heating element should not have anything to do with triggering the second pot. Turn off the coffee maker, change/refill the coffee, refill the reservoir and turn the pot back on. This works on my Cuisinart.
Dec 10, 2009 | Cuisinart DCC-2000
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee pot
As long ago as you posted this, the unit has a 3-year warranty - call Cuisinart and redeem it.
Jul 24, 2008 | Cuisinart Thermal DGB-600 Grinder
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Warmer stopped working
the coffee maker brews but the pot warming plate isn't hot
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
407 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
