Sanyo 47 inch black shadows
Sanyo TV has shadow on left side if you tap the screen sometimes will go away it used to just come on and go away after the TV warmed up can it be repaired ????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Tried to reseat the connectors going to the t-con board.
Posted on May 09, 2013
SOURCE: Shadowing on right side of TV
i had the same problem. it was the small mirriors (light tunnel)only one or two of the four mirriors have the tape. mine only had one taped. one of the other ones came loose blocking the light passing thru the tunnel on that side. you can fix this yourself (if like mine you are out of warranty) but it does involve taking some of it apart to get to the tunnel. then remove it and glue or epoxy it in place. mine has lasted for two months so far.you can go to www.avsforum.com and put in samsung shadow on screen it discribes the repair(alot of pages, it happens alot)
Posted on Mar 26, 2008
SOURCE: tv has sound but picture is black
good day.
The crt circuit of the unit might be loose or the the parts inside the board is loose. Have it hecked by a technician first. Minor parts inside might caused the problem.
Response is highly appreciated.
chris
Posted on Mar 29, 2008
SOURCE: lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Posted on Sep 23, 2008
SOURCE: Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Posted on Nov 23, 2008
SOURCE: dark shadow on samsung lcd tv
shadows being left when turning sumsung lcd television over
Posted on Apr 12, 2010
How do i fix a shadow in the center of the picture?
Does the problem go away of you tap the top or side of the set?
Jan 28, 2013 | Sanyo DP32648 32 in. LCD TV
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
43'' SAMSONG FLAT SCREEN. SHADOWS RADOMLY APPEAR
Is your tv a plasma tv or an lcd tv? When you say shadow, do yo mean a band across or down the screen, or is it a patchy shadow?
Mar 17, 2010 | Televison & Video
I have a Samsung LN-T4661FX/XXA 46'' LCD HDTV. It has an issue where there is a dark gray-ish shadow over the left 1/3 of the screen. This ''shadow'' starts almost exactly at the top center and goes down...
I also have the same problem but when i called a samsung tech they told me it was the board. They pulled the cables that you were talking about out and it didn't do anything. apprently he said there is something wrong with the panel cause if you try it, u can bend the panel and it will make it better for a while. But if you want to fix it, it's 1200 just for the panel which is bull and samsung won't fix it if you are out of warranty.
Nov 09, 2009 | Televison & Video
We have a 47 inch Vizio, Blue shadows
my vizio made a popping noise and then screen went black. tv has power
Aug 30, 2009 | Televison & Video
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Shadow on the screen
our 32 inches flate p tv is not turning on an off no power
please help
Feb 09, 2008 | Sanyo DP32746 32 in. LCD Television
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
