Question about CSi Speco DVR-16IP/160
Cannot pass the user Login. already reset it but need a user id and password.
Blackberry id password required?
Overview
There are two scenarios whereby a BlackBerry smartphone user is unable to log into BlackBerry World with the BlackBerry ID when the SIM card has been removed from the smartphone.
  1. If the SIM card is removed from a smartphone where a BlackBerry ID has not been previously set up, then the option to skip the login to BlackBerry ID will be available.
  2. If the SIM card is removed from a smartphone where a BlackBerry ID has already been set up, then the option to skip the login to BlackBerry ID will not be available. The BlackBerry smartphone user will be required to log in with the last known BlackBerry ID credentials.
Workaround
If the BlackBerry ID password has been forgotten but the answer to the password recovery question is known, select Forgot Password on the smartphone and answer the recovery question to generate a password reset email.
If the BlackBerry smartphone user knows the email address used for the BlackBerry ID login but is unable to remember the associated password then it is possible to reset the password using the steps below:
Note: If the BlackBerry ID account is not confirmed, it is necessary to provide the answer to the password recovery question as part of the web based password reset flow.
To see if a BlackBerry ID account is confirmed, log in to the BlackBerry ID account, select Account Details and locate the Email Status field.
  1. Browse to the following URL using a desktop browser, the BlackBerry Browser on the BlackBerry smartphone, or the Browser on the BlackBerry PlayBook: http://blackberryid.blackberry.com/bbid/recoverpassword
  2. Enter the BlackBerry ID Username (email address) and the CAPTCHA characters, then click Submit.
  3. Enter the Answer to the Password Recovery Question, then click OK.
    Note: Answering the recovery question is only required if the BlackBerry ID account is not confirmed.
  4. A confirmation message will be displayed A password reset email has been sent to email@domain.com, at which point, a reset email will be delivered to the associated email address inbox.
  5. Log in to the email account associated to the BlackBerry ID using the desktop browser, BlackBerry Browser on the smartphone, or the Browser on the BlackBerry PlayBook.
  6. Locate the password reset email and select the Change your BlackBerry ID password link.
    Note: The BlackBerry ID reset email will come from bbidpw-donotreply@blackberry.com. If the email is not found in the inbox, check the mailbox's Spam or Junk folder.
  7. When the password reset page loads, enter the Answer to the Password Recovery Question, enter the New Password, Confirm Password, then click Submit.
  8. A confirmation message will display once the changes have been saved successfully.
  9. Moving forward use the newly created password whenever logging into BlackBerry ID.
Apr 19, 2015 | Blackberry Cell Phones
Why cant I log into facebook
Login to FB-
1- you may have wrong password/user name
2- Your mail id or /user name may be blocked by FB.
3- Your Mobile No id verification have some problem.
Jan 27, 2015 | Facebook Computers & Internet
How to I log into my account
Enter user id and password and click on login button.
Jan 25, 2015 | Computers & Internet
Log on to my account
You need to user Id and password to login with your account then click on login button .
Jan 07, 2015 | Computers & Internet
Lost my pass word for facebook
Hi
If you are being blocked then it is likely that you are not entering the login details that Facebook is expecting, whether they have been satisfactory in the past or not.You could try this, go to the login page here:,
Facebook
just under where you input your password you can click on "forgotten password". This takes you to a page where it says "find my account" where you can enter "Email, Phone, Username or Full Name". Try entering one of these (My email gave the best result for me) and follow through the instructions to reset your password so that you can access your account.
If this does not work there are a number of options here depending upon what you have lost, ie you can't log in, your facebook page has been locked and you can't change it, or it no longer appears to exist. I could go through them all but it has already been done here:
How To Recover Your Facebook Account When You Can No Longer Log In
It details the methods you can try depending upon the exact circumstances.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Computers & Internet
I have somehow made 2 different accounts with the same exact login credentials. And now, it only allows me to access the second account I set up. How do I delete the first account, when the login...
its not possible.because facebook server not consider two login with same id.even any computer related service not consider it.see what computer do.
if you registar with one id than facebook store your Id and you login again than they match it with your added id and password and its ok than you can able to login.
if you registar again with same username and email than comeuter says "username already exist OR email address already registered".
Feb 11, 2011 | Facebook Social Network
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
I forgot login password for Ricoh Aficio MP2000 copier
Try getting into service mode and see if you can reset the user passwords by turning them off in the settings.
Do you know how to get into service mode?
Nov 17, 2008 | Ricoh Aficio 250 Copier
Windows xp pro login password
witch password?
ADMIN PASSWORD?
BIOS PASSWORD?
Nov 02, 2007 | Microsoft Windows XP Professional With...
CSi Speco DVR-16IP/160 Logo
Top CSi Speco Televison & Video Experts
 Russ Hill
Russ Hill
Are you a CSi Speco Televison and Video Expert? Answer questions, earn points and help others
