Question about Logitech Gamepad F310
Can I fix the Right trigger from activating randomly whether I press it or not?
Trigger sticking
How to fix rt trigger
Hi, Sabrina for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to repair an Xbox360 controller RT LT Trigger
XBOX ONE CONTROLLER TEAR DOWN AND REPAIR RIGHT TRIGGER NOT WORKING
How To Fix Your Xbox One Triggers When They Stick
Tech Xbox One Controller Right Trigger Constantly Activated xboxone
Jul 21, 2016 | Motorcycles
How do you reset all family settings on xbox 360
There are different codes for different 360 consoles and different dash versions:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up SCROLL TOP THE BOTTOM and type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in and hold it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
!!!HERE ARE MORE CODES THAT HAVE BEEN TESTED AND WORK!!!
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER (Do this twice)
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, X, X, UP, DOWN, DOWN. Then down, down again.
Left Trigger, Right trigger, X, Y, Left Bumper, Right Bumper, DOWN (dpad), Y, Left, Left
Jun 22, 2014 | Microsoft Xbox 360 Console
How do you fix a jammed trigger on the Ryobi 10 Amp Electric Power head
Not really a fix but it worked for me. I opened up the case. Their is a little black box with a red button that must be depressed. Pulling up on the trigger pushes the button. Their is what i call a counter press above the trigger. By pressing it, it makes room for the trigger to slide up and press the red button. There isn't much you can do improve this process. But i took the two springs off the trigger and depressed them trying to shorten them thus reducing the force needed to press. The counter press in spring load. I carefully stretch it by pulling on the end directly above the trigger(not against the frame). This took some pressure off the counter press. I finally took a small file and carefully filed down the edge of the counter press where the trigger presses against. This makes it slide upward easier even if the counter press isn't pressed down fully when you squeeze it. The trick is pressing the counter press first, but doing these things has made my trigger a lot smoother. It use to be a hard press to activate, but now it is 10 times better than it use to be. Good Luck!!
May 17, 2014 | Ryobi 10 Amp Electric Power Head RY15122
Xbox 360 controller right trigger always activates
There are a couple things you should try before buying a new controller. First, make sure that when you start your pc or xbox 360 that you are not pressing the trigger, as this can make it stick while it is on. Next, you can try to plug in/turn on the controller and then plug out/turn off the controller a few times in a row, this may work also. If neither of those work, then you could still try with a different console or pc, and if the problem persists to those, I would think about buying a new controller.
Oct 11, 2012 | Microsoft Xbox 360 Controller
My xbox 360 wired controller's right trigger is always activating without it being pressed
If the potentiometer for the trigger is bad or is not making good contact with the circuit board, say through a poor solder connection, this could be your problem. If the controller isn't getting any signal from the electronic trigger component it sees that as a pressed trigger and becomes grenade happy. This has happened to me.
Bob.
Cannot remember my Xbox 360's passcode and reset answer!
Try these steps first:
Go into settings .... console settings...then device settings or the blue screen then go...
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
x
If that doesn't work then call 1-800-4MYXBOX they will walk you through it.
Jul 04, 2009 | Microsoft Xbox 360 Console
2000 GRAND PRIX CUTS OFF WHILE DRIVING. IT DOES THIS RANDOMLY. SECURITY,LOW COOLANT,ABS AND SERVICE ENGINE SOON LIGHT ARE ON. THE KEY STICKS IN THE IGNITION RANDOMLY ALSO.HAS OVER 100000 MILES.
mass air flow sensor or o2 sensors for check engin light another problem could be the catalytic converter thats all i can help with right now im having the same problem with my key when i solve it i will be more than happy to share with everyone else..
Apr 08, 2009 | 2000 Pontiac Grand Prix
Non-responsive R trigger on X-box remote
OK with your left trigger it sounds like that you have a bad solder joint meaning that the solder connection has broken. Easy fix if you are good with soldering. Just open the DS find the button that is giving you problems and re-solder the connection. As for the right trigger, while you have the DS apart take some rubbing alcohol and a swab and wipe the area with the alcohol and clean with a soft towel like toilet paper or a napkin.
Feb 25, 2009 | Nintendo DS Console
Xbox 360 Controller right trigger doesnt work
Your controller is most likely exhibiting a hardware failure. Taking apart the device voids your warranty. When a button does not work anymore, it is safe to say that you will need to buy a new controller.
The Logitech Chillstream Gamepad is only $20 and works in the same fashion as the XBOX 360 Controller (uses the same xb360 XInput controller driver too!)
Give that a look.
Aug 24, 2008 | Microsoft Xbox 360 Controller
Logitech Gamepad F310 Logo
48 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
