Question about Karcher Turbo Nozzle Pressure Washer Quick Release
My pressure washer quick release nozzle is stuck on. How do I get it off
Water comes out of nozzle after releasing nozzle
Sounds like the trigger is stuck Mine did this and I took it apart and shot WD40 into all the working parts. Works now.
Jul 03, 2015 | Garden
How do I release stuck quick connect on my NorthStar pressure washer?
If it is a twist coupler which won't turn, i use a pipe wrench or channel locks. If it's a quick coupler socket and the sleeve won't pull back, the quick coupler plug is bad. If you can't get them apart, both should be replacedTodd Lehkereplaced.
Aug 22, 2014 | Northstar Garden
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
The trigger on the wand of my Karcher model K 368 M will not re-engage for several minutes after the trigger is released. If I repeatedly squeeze the trigger for a few minutes, eventually the switch will...
it sounds like a flow switch that is installed in the inlet of pump can get stuck at times if you have a soap nozzle select it usually more flow moves the flow switch try and clean the flow switch if possible.
Aug 10, 2013 | Karcher K3.68MR Electric Pressure Washer
There was a leak i undid the mottor and repaired it but some oil spilled out, now there is no leak but little pressure and mottor does not stop
A "chattering" pressure washer pump can be caused by many things. You could have a bent or damaged inlet line, or the water supply might be too low. Fixing these is simple, but checking on the water supply is critical. Never let the water supply run low for any extended period of time. Other causes of a chattering pump include water that is too hot, you may have air in the pump system or a stuck float valve. A power washer pump that is vibrating, but not chattering could be the result of air in the system or debris stuck in the valves. Catching these pressure washer problems early and knowing what causes them will save you a trip to the repair shop, especially when it comes to the low-water issue.
Troubleshooting Low Nozzle Pressure
Low nozzle pressure is a common complaint generally caused by one of the following:
1. Plugged nozzle tip.
2. Inlet screen plugged.
3. Insufficient flow in gallons per minute (not pressure) to the pump.
4. Unloader valve stuck open due to debris lodged under the check valve ball.
5. Customer use of shutoff-type quick connectors.
6. Plugged hose.
Troubleshooting Pressure Washer Soap Injector
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following:
1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed.
2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting.
3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector.
4. If you have an adjustable nozzle, be sure it is in the low pressure position(away from the gun) to draw soap.
Thanks
Apr 01, 2012 | Garden
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
I have filled the detergent tank of the Karcher k2.360 but when I start it up and spray the car the detergent does not come out water does but how do you get detergent to?
if you have quick release nozzles take the nozzle out and try it it will not pull soap with normal nozzles or under high pressure
Mar 25, 2012 | Karcher Garden
How do you change the nozzle? We borrowed this unit and can't figure it out.
On most pressure washers the nozzle is inserted into a quick connect. Simply grasp the outside of the housing holding the nozzle and pull back. The nozzle will come out. While holding the spring loaded connector back insert a new nozzle and release. In some case there is a slot and the quick connect must be orientated so the slot lines up with a pin. If the end looks like this, then it is a quick connect. Grasp it and pull back. ecae845.png
Apr 24, 2010 | Karcher 2500 PSI Pressure Washer
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Karcher Turbo Nozzle Pressure Washer Quick Release Logo
489 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
