Question about Samsung GT-C3520 Unlocked Quad-Band GSM Phone with 1.3MP Camera, MP3 Player, Social Networking and Bluetooth - US Warranty - Silver
Change soft keys - Samsung GT-C3520 Unlocked Quad-Band GSM Phone with 1.3MP Camera, MP3 Player, Social Networking and Bluetooth - US Warranty - Silver
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
I have a meridian m3820 and my password is locked out of my voicemail can you hep
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say m box, AA, and other, above the three soft keys
press the m box soft key
the screen should say add, Del , and change above the soft keys
press the change soft key
enter in the mailbox number you wish to reset the password on
press o k
the screen should say reset and next above the soft keys
press the reset soft key
press the RLS key
your password should be reset to 0000 The default .
Mar 14, 2011 | Nortel Meridian M3820 Corded Phone
I need to know how to change the name that shows up with each extension and how to access the voicemail if you do not have the previous users password?
I'm guessing that your looking to change the name on the telephone system and not the voice mail.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
The password on the mailbox that you don't know the password to will need to be reset to access that mailbox. While in admin programming you can change the name on the mailbox.
To reset your voice mail password,on press feature 983 the screen should say log:
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
press ok
If you pres the next soft key 2 or 3 more times you'll come to the name of the mailbox press Chng and enter in the new name (the # key advances by a space and pressing # twice puts the comma to separate the first and last name press ok when finished
press the Rls key
your password will be reset to 0000
Dec 08, 2010 | NorStar T7316E Corded Phone
It wants pin code and puk
To change the PIN number on the phone,
  1. Press Menu (left soft key)
  2. Highlight Settings and press OK (left soft key)
  3. Highlight Security and press OK (left soft key)
  4. Highlight Change codes and press OK (left soft key)
  5. Highlight PIN code and press OK (left soft key)
  6. Enter your old PIN code then press OK (left soft key)
  7. Enter your new PIN code then press OK (left soft key)
  8. Repeat your new PIN code then press OK (left soft key).
Aug 07, 2010 | LG GB102 TMOBILE PAY AS YOU GO MOBILE...
I need to change the password on my phone
To reset your voice mail password, press feature 983 the screen should say log:
press ok
press the Rls key
May 03, 2010 | NorStar M7310 Corded Phone
Chaging number of rings
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
Apr 15, 2010 | NorStar M7324 Telephone
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
V3i switch right and left soft keys
change feature icons & home keys
Change feature icons, soft key labels, and
smart key function in the home screen:
- > Settings > Personalize > Home Screen
> Home Keys
Oct 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Rings 15 times before going to voicemail.
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Oct 06, 2009 | NorStar Startalk Flash 2 Phone
Samsung GT-C3520 Unlocked Quad-Band GSM Phone with 1.3MP Camera, MP3 Player, Social Networking and Bluetooth - US Warranty - Silver Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
