Can 2gb memmory run windows vista - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
Yes
The problem was the Ram Memory was too low.
1GB won't perform very well. 2GB should get things running fairly decent.
Windows AeroGlass windows manager, requires more Ram Memory, than the usual Windows windows manager.
Regards,
joecoolvette
Posted on May 07, 2013
In my nokia 5200 , only external memmory of 2gb . How can i increase my phon's external memmory up to minimum range up to 4gb .
hi try going into the phones settings and select memory then go to external memory and choose increase to maximum if that doesnt work then try inserting a blank 4gb memory card and then formatting it in the phone may work that way.
Apr 08, 2013 | Nokia 5200 Cellular Phone
As i inserted my 8gb sd card to my lg viewty and formatted the memmory seems to be reduced to 1.74 gb. how to recover rest of my memmory
Hello, it's quite possible your LG Viewty doesn't support SDHC cards...only SD cards. If it's bigger than 2GB then it's NOT an SD card...but a SDHC one (The HC stands for high capacity) There's quire a difference between the 2 types.
You could check the spec. of your LG thing to see if SDHC cards are supported.
Regards
Nicam49
Apr 27, 2011 | SanDisk Extreme III 2GB Secure Digital...
My phone is Samsung m620,I used 2gb memory card when I tried tranfer music from other phone to mine it said memory full while it is empty. It does not has songs at all. Ineed help please.
Your memmory card will be in FAT 32 format.You have to change the memmory card format to NTFS.Remove the card then connect the memmory card with memmory card reader and select property to format it
Sep 27, 2010 | Cell Phones
My hpf1905e is no longer uploading pictures from
pls check on the device manger after inserting memmory stick
if any yellow colour is there.you should install drivers for memmory card
Oct 30, 2009 | HP Pavilion dv6000z Notebook
Can not install windows vista , but ok with windows XP
yes it can run Vista with just the on board video
Sep 22, 2009 | Computers & Internet
Dear friends, i am also getting this During the startup I get 2 beeps, first one on the Intel logo screen , and then another slightly longer beep right before Windows loading screen  i need help!  my...
try running a memmory test on your memmory. I use "Hiren's Boot Disk" to run these kinds of checks. If your RAM has any problems, it will show it.
Also, does the game crash and return you to your desktop? Or does the PC reboot? Or does it Blue Screen?
It also "might" be incompatability?
Jan 05, 2009 | Computers & Internet
Low disk space recovery D
Option 1: Vista itself requiers a large amount of memmory, consider switching to a less demanding operating system like Windows XP, If you prefer the Vista look you can get themes that make Windows XP look like vista (Remember: you will need to backup files which you wish to keep).
Option 2: Insert you vista disk and follow on screen instructions to modify which vista components you want on your computer or use the add/remove windows components wizard on you computer, you may find there are parts of vista you do not require.
Option 3: Continue what you have already started.
Dec 20, 2008 | Compaq Evo N610C Notebook
Foxconn motherboard, ram problem
You need paired memory - and if you are using two pairs, they must be the same speed (there is a big difference between 33Mhz and 677Mhz)
Apr 03, 2008 | Computers & Internet
Code 10 Error
Issues: Code 10 error, Physical Memory is 2GB +
1. Go to http://www.station-drivers.com/page/marvell.htm
and download the Marvell Libertas driver Version 1.0.0.53 date: 10/16/2007
2. Run the self-extracting Zip file to uncompress the driver files
3. Under driver\inf\Vista...\32BITS there is a file called "netmw13b". Copy this file to c:\windows\system32\drivers, overwriting the file that is currently there
4. Reboot Vista
There. Four easy steps. Someone please give this a try and let us know whether it's really that simple.
Notes...
32 bit Vista SP1 will install a May '07 driver which will not allow more than 2Gb RAM .Run InvokeSetup after extracting and v. 1.0.0.53 of the driver will be installed. After doing this I added 2GB more RAM (4GB total) and everything works.
Jan 18, 2008 | NetGear - WG311 - 54Mbps 802.11g/b...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
