Sony wega kdfe60a20 we through diagnose the - Televison & Video
Sony wega kdfe60a20 we through diagnose the problem set says lamp error lamp cover lamp driver where do I get the part and exactly what do I get thanks
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Check whether the lamp cover has been closed well. There is a switch inside the lamp cover, that will only engage properly after the lamp cover is fixed well. If not, lamp error will be displayed. To get proper support, it will be best to contact the authorized service center for Sony. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
Posted on May 08, 2013
  • 87 Answers
SOURCE: Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Feb 09, 2009
welcomejee
  • 10594 Answers
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
Posted on May 02, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
  • 1527 Answers
SOURCE: how can you test if sony grand wega lamp is faulty
hello if the lamp is faulty the bottom light will flash on the front of tv. the other way is to take the front cover off and check the lamp by eye. the wire inside the lamp will be burn't good luck
shaun
Posted on Oct 24, 2009
Testimonial: "hi thanks for your help i wiil try this."
SOURCE: reset lamp hours on sony grand wega
I just replaced the lamp on my Sony Wega 51 inch LCD Projection TV and it still doesn't work. Before I changed the lamp I was seeing the lamp indicator blinking green so I knew it needed to be changed. I bought a new one, as recommended by so many other people I saw online who were having the same problem, but after I installed it it didn't work. I turned the power on, you can hear it click and the power light turns green, then 5 seconds later the power light switches to blinking red. Someone help me please!!!!!
Posted on Mar 21, 2010
WHERE CAN I BUT THERMAL FUSE FOR SONY WEGA 60"LCD PROJECTION TV KDFE60A20
This is the part number: 1-910-023-93
https://sony.encompass.com/search/
May 07, 2015 | Sony WEGA 60" 1366 x 768 LCD Projection TV...
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I HAVE A SONY WEGA PROJECTOR TV KDFE60A20 I CHANGED THE LAMP AND THE PICTURE IS TOO DARK BEFORE I WATCHED THE TV FROM THE SIDE WITH THE WINDOWS OPEN AND NO PROBLEM NOW I HAVE TO CLOSE THE WINDOWS AND
my first thought would be new bulb needed but if you have changed bulb can't be that.
is the wall white?
is there a setting to say what colour you are projecting on?
good luck
Jan 20, 2013 | Sony Lamp For Sony KDFE60A20...
Sony FD Trinitron WEGA KV-32HS500 --had the 7 blinks problem, took out D board and resoldered pins--didn't work. But now it blinks 3 times!!\r\n . . .I guess I still have to replace those IC's Anyone have...
On some models 3 blinks pertain to a lamp cover error, lamp cover is not attached securely or lamp is not set securely causing no picture or sound. There are switches or sensors that interlock and send signals to the board telling it is set securely.
Feb 28, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony Grand Wega KDFE60A20 stay on for 30 secons and then goes off for another 30 seconds, can you please tell me what's wrong whith it. thans
Its symptom of weak lamp and TV needs lamp replacement.
Please buy Sony original lamp and avoid after market / cheap lamp.
Jun 22, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Tv lamp
If its Sony KDF-E60A20then click Sony Support to download user manual. Go to page-76 of that manual where you will see detailed instruction about lamp replacement in this model.
Apr 21, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
POWER LIGHT BLINKS 5 TIMES
That's the LA-3 LCD projection unit. 5 blinks on that model means a lamp driver error. You would need the service manual to diagnose exactly whats wrong with the system. I have included a link where you can get the entire 121 page service manual for your set if you would like it. It cost 15.99 and they will email it to you and provide free support to help you diagnose it. Here is the link if you would like the service manual.
http://servicemanuals.vstore.ca/
Feb 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
