Question about NorStar T7316E Corded Phone
How to connect the phone to the phone line when it says "keycode read"
I cannot connect the phone lines
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
A key code is required to expand the number of allowed extensions.
Posted on Jan 27, 2014
Keycode reqd
The BCM 50 can be key coded for up to 12 extensions on the main cabinet. Expansions cabinets use one key code to cover whatever Media Bay Module is installed. If you have an expansion cabinet with extensions it is possible that the extensions on the main cabinet did not get key coded. I have had a system with an expansion cabinet and only key coded eight extensions in the main cabinet because it was cheaper. This can be checked in the system / key codes area of programming.
Jul 30, 2013 | NorStar T7316E Corded Phone
Had a very close lightening strike in my back yard. Everything was connected to a sorge protector. It fried my Cox Cable modem, my telephone and the #2 phone jack on my all-in-one. Bought new phone and...
Yes it is likely the HP All In One is damaged - I suggest you put your money towards a new All In One as a repair most likely would not be a cost effective solution.
Jun 09, 2011 | HP OfficeJet J4580 All-In-One Laser...
We have the L 7680. Last week we changed from ATT dsl line with filter to ATT Uverse. They installed. With the change, our fax stopped working in/out. It reads as No Answer from outbound attempts and...
The Uverse service appears to be all digital - so any voice/phone channels are going to be VOIP....not real analog lines as you had before. So, you need to connect the HP fax to a phone line service. Did ATT provide you a phone number? (or perhaps 2 phone numbers) Then the fax should be connected to that line. If you are unsure, then connect a phone to the provided line and listen for dial tone. If you are connecting a fax to a VOIP line then a good suggestion is to drop the fax speed to 9600....this will provide more reliable connections. Hope this helps
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
While talking on the phone the fax will redail even though there are no faxes trying to go through. We use this line to answer manually and receive faxes.
I have seen this problem happen on printers that have old firmware versions. Go to this link. http://bit.ly/biqa0o and type in the keycode box in first this keycode 401ec4 that will download the newest firmware to your computer. Then to send it to your printer download the following from the same link just use this keycode usbflash that will download a usb utility that will help you flash the new firmware to your printer. The X340 needs to be connected to your computer via USB.
Dec 08, 2009 | Lexmark X340n All-In-One Laser Printer
When I fisrst connected system to phone line thru rj31x jack everything seemed to work as it should. When I deliberately created an alarm the system seized the phone line, dialed my cell phone, and told me...
When you get the call on your cell are you supposed to do something to let the panel know the signal went through. It sounds like it still has the line siezed for some reason.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
Lined and orange
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 14, 2009 | Canon PowerShot A80 Digital Camera
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
Faxing with a digital phone line
I looked up fax problems at HP.com and my guess, based on what I read, is that the 6110 is able to detect the broadband data connection at the higher line frequencies, even though all you hear on the line is a normal dial tone. If you haven't done so already, you'll need to install a line filter on one of your phone jacks (this should have come in the kit with the rest of the hardware you were sent to set up the DSL line). This isn't an issue with the 6110, but a natural "consequence" of using DSL.
Here's the web page I used as the basic for this opinion:
Phone "Off the Hook" Status
On that page scroll down to the "Checking the phone line" section and read the material there. See if that info helps. Good luck.
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA MP780 creates an "off-hook" condition for phone line 2
Does your Pixma multifunction printer have two lines in? for line 1 and line 2? Your active line should be in line 1 of course.
However, I do not think your printer is the source of the problem.
When the phone company turns off line 2 they can do it one of three ways depending on the generation of your local telephone system.
At the back of your home or in the office building there should be a telephone network interface box. Once section if open to the customer to do basic tests, the other is reserved an uses a security screw head to keep you out. You have either red/green and yellow/black or blue/blue-white and orange orange-white wires. Each color refers to tip and ring in telephone polarity. If these are reversed your phone will work but not well.
For your smart phone with two lines in, I'd check out at the box and switch the wires for black/yellow or orange orange-white. When these are reversed the 'polarity' is off but voltage would still be present. In your case, the smart phone MAY be reading the crossed wires and giving you a line open vs. a line empty/disconnected which is nearly the same thing.
If you still have the second set of lines connected to your phone disconnect them from the phone and then underneath the phone you MAY find a switch to hard set your phone for single line or double line.
Let me know how you make out.
Regards,
Worldvet
Sep 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
NorStar T7316E Corded Phone Logo
47 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
