Question about HP Computers & Internet
Parity check 2 - HP Computers & Internet
  • HP Master
  • 2,878 Answers
Memory error
Posted on May 07, 2013
Parity check
This is ith the RAM in the omputerin the giving you thqt defect. replae the RAM and it will fix the problem.
May 04, 2013 | HP Computers & Internet
HP d530 920 & 162 Error And Parity Check 2 Hold On
Try installing the original RAM and see if the computer boots up.
If it does then the other RAM modules maybe incompatible or faulty.
Try using additional or new of the same make and speed as your original RAM.
Apr 16, 2013 | HP Compaq d530 SFF PC Desktop
SCREEN SHOW PARITY CHECK 2
Might be DIMM (memory) number 2 going bad.
Jan 11, 2013 | Acer Aspire 5602WLMI Notebook
NOW COMES UP WITH PARITY CHECK 2
Reseat Memory Mods. May be a Memory failure.
Just powering on my new ASUS M4A88T-V EVO Motherboard to check if I have my connections done right, Receiving two short beeps then no beeps, Trying to find out what that means
2 Beeps? maybe Parity circuit failure
it is responsible for generating and checking the parity bit on the system memory when parity checking is used. This circuitry is not working properly.
This code usually means a problem with either the system memory or the motherboard.
Try to reset the cmos remove the battery. if not check the memory,try clean the gold surface of the memory using pencil eraser.
Sep 23, 2011 | ASUS M4A88TV EVOUSB3 Motherboard
Parity error :only when im playing games, after playing a game 20 minutes (10 if it has good graphics) the computer screen goes blue and it says "Call your hardware vendor for support NMI: Parity check/...
increase ur virtual memory then for high resolution game u should install a graphics card , nvidia graphics card is the good quality card . After doing that plz check
Jun 01, 2009 | IBM Lenovo ThinkPad R60 Notebook
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Monitor blackscreen
If you have access to an external monitor then conncet that to the external monitor port. Holding the function key and F7 or F8 should switch the computer to the external monitor. If this is OK then I'd say your mercury lamp has burned out. If no access email back the beep code. You'll have to listen carefully. In either case this computer will need to be repaired by a reputable computer repair person.
Good Luck
Mar 22, 2009 | HP Pavilion dv9000z Notebook
PC beep 5-2-2-1 code on startup, no posting
I THINK IT IS MEMORY UPGRADE, ALSO MAYBE A PARITY ERROR, SOME MEMORY DO NOT NEED PARITY ON THE CHIP SET, AND IF IT HAS PARITY ON THE CHIP THAN YOU GET ERRORS,
REMOVE THE NEW MEMORY AND SEE IF THE MACHINE WILL WORK IF SO THAN THERE IS SOMETHING WRONG WITH THE NEW MEMORY,
RAM TYPE: EDO, PARITY AND NON PARITY MEMORY, FPM MEMORY, THE CACHING MEMORY NEEDTO TO HAVE L1 OR L2 OR EVEN L3 CACHING CAPABILITIES,NMI ERRORS .
not:::: EAch manifacture may have a different voltage in the curcuitry and it may have the wrong voltage but i think that way out there and not to even consider it.....
does the manufact even allow that much ram upgrade???
rod
Feb 03, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
