Question about Garden
Homelite chainsaw model ut10580a
Wont satrt, fuel is not entering into chamber
  • 2,239 Answers
First place to start is replacing the fuel filter in the fuel tank, hook the hose out through the open filler hole with a piece of bent wire, replace the filter on the end.
Posted on May 09, 2013
  • 42 Answers
SOURCE: On a homelite chainsaw model d3300 i have all fuel
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Posted on Mar 15, 2009
SOURCE: homelite chainsaw carb adjustments
bear973 you must make sure that that in tank filter is seated in right position and not just floating around inside the tamk
Posted on Mar 24, 2009
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: On Homelite chainsaw model 410, where is the fuel
In the tank on the free end of the hose. HTH
Lou
Posted on Oct 06, 2009
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
CHAIN SAW HOMELITE FUEL
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
Sep 15, 2012 | Homelite Garden
I cannot locate my owners manual and have not used the Homelite Ranger 16 inch in quite some time --- What is the fuel and oil requirement??
most 2 stroke Homelite chainsaws run on a fuel/oil mix of 50:1 --- But on some older model saws they say to use 40:1 mix.
I own several 2 stroke machines and I use 50:1 on everything and they all run fine ( even when they say 40:1 ).
c...
Jan 19, 2011 | Homelite ZR10926 16 Chain Saw
Its sparking but not fireing for homelite 42 cc chainsaw. wat could it be ?
Try pouring a small amount of fuel mix into the spark lug hole and try for start. If it pops several times, then check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines and primer bulb. Does the primer bulb draw fuel into itself after several pumps? If still no help, go to: http://www.drystacked.com for a 12 page PDF article on Walbro brand carburetor theory and troubleshooting help. Pay particular attention to the location of the lower chamber gasket as shown in the article. Hope this helps!
Sep 05, 2010 | Homelite ZR10580 FactoryReconditioned 42cc...
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
Why will homelite 290 chainsaw not start?
Make sure you have blue, snappy spark at the plug (set at 0.020"). If ok, put some fuel mix in the plug hole and try to start--it should pop several times. If pops, then check the fuel system. Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors for theory and troubleshooting. Be sure to check the placement of the gasket in the lower chamber. Hope this helps!
Jun 02, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
Will not start - new fuel 50-1 mixture, checked filter- ok, spark plug sparks, cylinder has compression, finger test, 45cc, aprx 5 month old.
Will it start if you pull the plug and spray starting fluid in the chamber? if so then I'll bet you have a blown diaphragm in the carb or a plugged fuel filter or a bad gas line. hope this helps. Jeepfxr
Oct 08, 2009 | Homelite ZR10926 16" Chain Saw
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Homelite XL 101, what are cc's?
cc stands for cubic centermeters..It is a measurement of the chamber that the piston resides in when totally expacted
May 09, 2009 | Homelite Garden
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
