Zebra 220xi4 The ribbon creates a crease as it enters the print head. It creates a crease across the label.
  • 7,733 Answers
Your printer need service.
Posted on May 12, 2013
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
SOURCE: Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Posted on Aug 04, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
I am a Reseller and one of my client is having Citizen CLP-7202e. due to the faulty print head we have tried to change the print head and after changing a new print head, printer is not printing...
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Jun 14, 2011 | Citizen CLP-7202e Thermal Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Mar 27, 2009 | Zebra Z4M Printer
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Problem with my Epson Dot Matrix printer
Chances are, you didn't installed the ribbon correctly...
A. Open the printer cover
B. Use a pin to guide the ribbon between the print head and the ribbon guide, then turn the ribbon tightening knob to help feed the ribbon into place, it shouldn't be twisted or creased.
C. Slide the print head from side to side to make sure it moves smoothly
Feb 21, 2008 | Epson LX-300 Matrix Printer
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
TAKE UP RIBBON
I work with Zebra printers daily and I have found several ways to enable a stuborn ribbon motor. The S300 is the hardest to turn on but unless the belt has broken or come off it can be done. The S400 and S600 are much easier, below are a couple step that work for me.
Enabling/Disabling the Ribbon motor
Turn off the printer.
Disabling the motor – Press the FEED, CANCEL and MODE buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out.
Enabling the motor – Open the printhead and retract the ribbon completely onto the supply spool. Leave the printhead open. Press the PAUSE, FEED and CANCEL buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out. When the printhead light begins to blink, reinstall the ribbon and close the printhead.
The printer may or may not print out a ribbon sensor profile, this is normal. Cycle the power and you should be good to go.
Oct 16, 2007 | Zebra Stripe S600 Thermal Label Printer
46 people viewed this question
k24674
jasbo
jasbo
