Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
No d drive
I had a d drive and have been using it to burn photos to disc, and have been playing sims etc. today my d drive has gone!!!!!!i keep recieving error code 39 and or files missing. please help.
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
    Problem Solver:
  • 25 Answers
Hello the issue is with the registry on you computers.the system cannot read your device driver for the cd device. it is a matter of refreshing the registry butyou have to be careful in doing this. futher help let me know. RESOLUTION WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk. There are two supported methods to resolve this issue. Back to the top Method One 1. Remove the Upperfilters and Lowerfilters values completely from the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} NOTE: If you are getting a code 39 message, it may be that additional third-party filter drivers were added to UpperFilters and LowerFilters values in addition to Adaptec filter drivers. In that case, you may try to remove the non-Adaptec filter drivers first, leaving the Easy Creator filters in place to see if the Code 39 goes away. If you still receive an error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters values completely in the preceding key. 2. Restart your computer.
Posted on Aug 11, 2007
SOURCE:
My DVD Slideshow will only play on my PC.
To play on a dvd player the files must have an extension the dvd player understands i.e. .avi, .mpg4, .mvk etc.
May 17, 2016 | Computers & Internet
Li1705 Amilo cd & dvd faults
Dear david read
Your dvd rom is read only,you need a dvd writer to be able to burn cd and dvd
Best Regards
Mazagange
Jan 06, 2013 | Fujitsu Siemens Computers & Internet
I am new to the computer world & need some help ? How do i transfer my pictures from my computer to a disc ? Thanks
This is for windows 7:
Click the Burn button.
  1. Open your Pictures library from the Start menu and select your desired photos.
  2. Select the photos and folders you want to copy by holding down the Ctrl key and clicking their icons. Or, to select all the photos within a folder, press Ctrl+A.
  3. Need to select photos from multiple folders? Don't select any photos or folders in this step. Proceed with the rest of the burn process and Windows 7 will open an empty window showing the newly inserted disc's contents: nothing. Drag and drop the photos you want to burn into that window. When you're ready, go back to the Pictures Library and click Burn.
  4. Insert a blank CD or DVD into your writable disc drive.
  5. Decide how you want to use the disc:
    1. Like a USB flash drive:
    2. Choose this option when you intend for other PCs to read the disc. Windows 7 treats the disc much like a folder, letting you copy additional photos to the disc later.
    3. With a CD/DVD player: Choose this option to create discs that play on CD and DVD players attached to TVs. Don't choose this unless you plan to view the disc on a TV. You can't add any images to this disc later, so be sure to get them all selected the first time.
  6. Type a name for your disc and click Next.
  7. Click the Burn or Burn to Disc button again, if necessary.
PCHELPSTER007 from youtube. (If I helped you please rate me, if not, feel free to reply)
Jul 06, 2011 | Office Equipment & Supplies
How to download photos to cd r disc
You will open the photo from internet from any free side .Right click on the pic and save as to your destination. After download all the pic burn cd from data option,
Hope this helps.
Contract for more information.
May 18, 2011 | Toshiba Satellite L500 Series Notebook
I get failure to print on Slideshow Expressions show I have created for a funeral.
Do you mean you're not able to burn the show that you've created to disc?
If that's the case, try this. Firstly, make sure you are using the correct disc, eg. DVD+R. Secondly, make sure that you have selected the writer drive and not the hard drive: After clicking on "Produce" and then "Burn to disc", a window appears with settings for you to choose from. At the place where it says "Write to", choose your writer drive - if it says "Hard Drive", your show will not be burned to disc. Thirdly, you should know that SlideShow Expressions seems to experience some problems related to photo size and project length. I've had this problem myself. I've been able to burn slideshow projects with between 300 and 390 photos in them, using the original size photos (as large as 1MB to over 2MB). However, when I tried to burn a project containing 466 photos (10 chapters), my writer wouldn't work. The problem was solved by reducing the size of my largest photos. I experimented with size, and eventually had all the photos in this project resized to under 500 KB each. It worked: I was able to burn to disc. The project had music and text and it looked great. Resizing doesn't necessarily mean that the quality of the photos in your project will drop. I used Microsoft Office Picture Manager to resize my photos and there is no visual difference between the originals and the photos in the project. Just remember to keep copies of the originals so you don't lose them. I then burned a Data CD with the original photos on them and added it to the project as an extra. Fourthly, I learned from Individual Software's technical support team (online) that when you use large photos and combine it with the option to archive your photos and music on the disc, the writer drive can fail to burn. Also: make sure that your computer meet all the requirements of the software - given on the product's box. I wish you all the best. 11407336
Nov 09, 2010 | Individual SlideShow Expressions
Sims to double deluxe eror report!!!!!!
You have to have the disc in your cd/dvd drive to play the game. the game will not play without the disc. If you have any expansion packs installed you need to use the latest expansion disc. For instance, I have Free Time but not Apartment Life so I must have the Free Time disc in the drive to play the Sims 2, not the Sims 2 disc.
Jan 27, 2010 | EA - Electronic Arts The Sims Double...
Unable to read cds /dvds, made by me, of my photos. It will play pre recorded DVDs. ie Palin set. can see files but then computer hangs. Running Vista. Similar occurs on my desktop but I get the blue...
lost of things could be happening ,depending on optical drive manufacturer,file type,plus or minus dvd/cd blank disk and burning software and how you are burning the media,all can cause malfunctions,but if playing a disc causes blue screen of death,then i would first uninstall display adapter driver on graphics card,and restart,when computer finds new hardware,click cancel,go to dell support and get newest driver,and software,reinstall..some optical drives like minus discs,some like plus discs,depending on the drive,if its a combo drive and will read and write both plus and minus discs,then the problem is how you are burning them,or the laser is dirty or drive is malfunctioning.if you arent allready using nero burning software,then i would reccomend it,i have been doing this a long time,had my days of problems,,not anymore,i dont work for nero nor am i paid by them to say this, but i am a computer repair tech with 25+years experience,save yourself hours of pain and wasted blank discs,and purchase it,user friendly ,easy to use ,and advanced drive speed tools ,allow max preformance on any computer,read instructions ,discs must be burned with correct file type for device that plays them back ,disc at once or track at once settings ,matter,also using the slowest burning speed,creates a higher quality disc,but takes longer,post comments if you have more questions ,aloha from maui todd0708
Nov 13, 2009 | Dell Dimension 2400 PC Desktop
I am trying to burn a disc and bought4.7gb discs single use cd -r i have an acer aspire 5315 but it keeps saying there is no disc in dvd drive to burn i have tryed everything it is driving me mad can you...
some times it is the softwear u r using playing up, if so try using nero 7 as it is more user friendly then nero 8... it could also be ur burner playing up in witch case just trying holding the drive shut while it reads the disk... this can some times solve the problem....
mike
Nov 04, 2008 | Acer Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
